PickleRick
- Joined
- Nov 29, 2017
- Location
- Greenville sc
- TDI
- 05 GLS BHW sedan 5 speed conversion. BHW Carver SantaCruz in progress
So the 700r4 has a tv (kick down cable) the BHW is throttle by wire.
Has anyone mated these two? If so did you find a way to attach it to the throttle pedal?
Or did you ditch the 700r4 for a 4l60e and use a stand alone tcu since (iirc) the 4l60e doesn't use a tv cable.
My little s10 might be getting an upgrade in place of the 4.3
Also is there a stall speed that the tdi would like? I can get a 6.2 chevy diesel torque converter that attaches to the 700r4
