mbesemann
I recently got a Malone stage 2 tune and a Rawtek DPF + EGR delete kit (high flow cat, stock muffler).
The smell inside the vehicle is a lot stronger than expected. Even getting into the car after being parked overnight, there's a residual diesel smell (presumably lingering on the interior fabrics). Just wanted to see if others have experienced the same after doing deletes or should I be checking the exhaust for leaks (bad weld somewhere?)
I can't see myself enjoying this car if the smell will be that strong for the remainder of its lifespan.
