Hey guys!
I'm driving a Bora with AJM (PD 115) engine. Current mileage is 229tkm. It's stock so far, I have a PD100 (almost the same as PD150) inlet manifold with Darkside Racepipe waiting.
Well, the reason I'm posting here is that I want more power.
I like Fab176s old setup a lot. I'm aiming for similar numbers.
But the main problem is my budget.
Would be new H beam con rods necessary? It think I should rebuild the block at least, precisely because I think when I'm ready to modify it, it would already hit the 250k km mark. Next thing. The clutch. Sachs clutch + SMF would be over 1k€, is there any cheaper solution?
I'd be okay with less power, but then I should noticeable cheaper too.
Also thinking about getting a custom remap first, is there a remapper in central Europe/Germany you'd recommend me? ryanp is too far away
TIA!
TIA!
