View Poll Results: Which AMSOIL?
Premium API CJ-4 Diesel Oil (DEO) 100 28.25%
European Car Formula Motor Oil (AFL) 254 71.75%
Voters: 354. You may not vote on this poll
Old June 4th, 2011, 12:29   #1546
Crows Synthetics
Crows Synthetics's Avatar
TDI(s): 2009 Jeta
Fuel Economy: 38-42
Post
Originally Posted by 40X40 View Post
Please understand the every reference to Amsoil usage in ANY vehicle other than a TDI on this forum is a waste of your time and ours.
It matters not one whit how well (or poorly) Amsoil does in a non-TDI engine...... We are only concerned with TDIs here.
Perhaps you can correspond with Tooslick via PM instead of muddying the one thread that is allocated on here to your brand.
Tooslick has done a fine job here of providing clear information with a minimum of confusion and sales pressure.
Thanks for your consideration on this matter,
Bill
I think you missed my point completely.
It is just a reference on how well it works in other applications & I wish Amsoil would have said I could use it in the TDI.
Bill
2009 Jetta Sedan TDI --- 2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD---New Holland T1520 Diesel
Bill Crow - Amsoil Direct Distributor
www.FreeOilHelp.com --- www.BillsOilHelp.com
Crows Synthetics is offline   Reply With Quote
Old June 4th, 2011, 13:58   #1547
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
so it works well in a completely different engine. Good to know.
now, about VW TDIs then.
DPM is offline   Reply With Quote
Old June 4th, 2011, 14:23   #1548
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
If that motor has flat tappets then the info is relevant.
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old June 4th, 2011, 14:30   #1549
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
If the flat tappets are in a TDI, yes. Otherwise NO. Look, there is plenty of TDI/Amsoil experience out there without dragging in every other engine in the universe. If the Amsoil dealer has TDI relevant info, post it. If not, why not leave the Amsoil selling to a dealer that DOES have TDI/Amsoil data???
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old June 4th, 2011, 15:59   #1550
Crows Synthetics
TDI(s): 2009 Jeta
Fuel Economy: 38-42
Post
FYI I do have a TDI 2009 and the 2003 PSD as it states in my signature.
Also the flat tappet reference implies it can with stand harsh environments like the TDI does as well.
I am a dealer.
Bill
Old June 4th, 2011, 17:59   #1551
SuburbanTDI
I think the Amsoil representative makes as good a point as any other Amsoil dealer to recommend 3000 HDD 5w30 oil, the new AEL 5w30 AME or ARO for the newer PD and common rail TDI diesel engines.
Some would prefer to stick with the VW505.01 & VW507.00 which Amsoil has never had any of their oils certified as.
Certainly though TDI owners are free to choose from either the Amsoil offerings or any of the Certified VW505/507 oils offered widely elsewhere.
SuburbanTDI is offline   Reply With Quote
Old June 4th, 2011, 23:28   #1552
TooSlick
TDI(s): Audi 100S
Bill,
The VW 507.00 oils like AEL aren't the best choice for the PD engines either. The results with those have been very mixed. I'm very familiar with the additive chemistry of all these Amsoil products and the Series 3000 is too thin for the PD engines, period. Most of your larger diesel engines have rollerized valveltrains and the results simply don't translate to the TDI. It really is a somewhat unique application with regards to lube requirements.
TS
TooSlick is offline   Reply With Quote
Old June 5th, 2011, 06:42   #1553
Crows Synthetics
TDI(s): 2009 Jeta
Fuel Economy: 38-42
Originally Posted by TooSlick View Post
Bill,
TS
Thanks for that explanation.
Bill
Old June 5th, 2011, 07:17   #1554
TooSlick
TDI(s): Audi 100S
Bill,
I've been following this board for 12 years and have probably reviewed several hundred oil analyses from TDI's. Folks have tried all these things you've considered doing and we now know what works and what doesnt. For example, the VW 506.01 Spec oils were tried in the PD engines when they first came out. This is a thin, 0w-30 oil that's formulated to improve fuel efficiency. It has lots of ZDDP as well as a fair amount of moly. There were some horrible results with this very thin oil in the PD's, as well as in some earlier variants of the TDI engine. By contrast, results with the 5w-40, API spec diesel oils (Mobil 1/TDT, Amsoil DEO, Shell Rotella T, Schaeffers, etc), in the PD's have been overwhelmingly
excellent.
You're certainly welcome to experiment and try different types of oils in these engines. But I try to limit those experiments to my personal vehicles & equipment.
TS
Old June 5th, 2011, 19:58   #1555
SuburbanTDI
TS
I'd agree that experimental use of Non-VW505/507 oils should be approached with ample caveats and never recommended to others, experiments should be limited to personal vehicles and equipment.
However you, like every other Amsoil dealer I can recall, have also gone off the reservation and recommended commercial products that not even Amsoil suggests for this application.
As an Amsoil agent and commercial salesman are you warranting the use of, and fully indemnifying the TDI PD owners that follow your professional recommendation from just yesterday: "I actually think the best Amsoil product for the VW PD's is their 10w-40/AMO"
It's a legitimate question to ask, whose responsible when you, a professional representative and agent of Amsoil, push and sell a product for an application and it destroys an engine down the road?
Old June 5th, 2011, 20:02   #1556
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
As an Amsoil agent and commercial salesman are you warranting the use of, and fully indemnifying the TDI PD owners that follow your professional recommendation: "I actually think the best Amsoil product for the VW PD's is their 10w-40/AMO"
No such relationship exists. Amsoil dealers are independent, not Amsoil employees.
What happens when TDT or T6 destroys an engine based on recommendations on this site?
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old June 5th, 2011, 20:05   #1557
SuburbanTDI
So the Amsoil warranty is useless?
Using what's recommended by your Amsoil professional is at your own risk?
Old June 6th, 2011, 02:48   #1558
BEN721364
TDI(s): 2009 sedan
Post #1523. Without specifics there's not much of a statement is it? Some specifics may include:
"I don't agree with Amsoil allowing extended drains"
"I don't agree with Amsoil not being officially tested"
"I don't agree with their testing or marketing methods"
Any of those?
Post # 1523 was mine. I repeat, "I recommend that you be guided by the vehicle manufacturer's recommendations with respect to lubricant types and specifications; rather than hype from a lubricant manufacturer or blender. VW includes this information in the materials that came with the car."
It appears that you advocate disregarding the vehicle manufacturer's recommendations/admonishments with respect to lubricant 'certifications' and instead advocate that folks be guided by advertising copy and brochure hype from lubricant marketers. Fair characterization? If so, I respectfully disagree. While API (as one example) certification entails some expense, it (and or others) is the price of admission to the sandlot, IMO. It's not that I "distrust" marketers of non-certified products...
BEN721364 is offline   Reply With Quote
Old June 6th, 2011, 07:46   #1559
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
The Amsoil warranty is not useless. Follow your OEM recommendations if you want that (AFL in a PD). Don't expect them to warranty a factory mechanical issue though, even if you used the oil specified by the OEM.
What I mean is this: Say you use Castrol TXT 505.01 [or other 505.01 oil] in your PD, and have cam issues at 100K miles. Neither VW nor Castrol [or other company] will do anything about it. Out of factory warranty and it's not a lubricant failure.
Same situation with an API oil like TDT, T6, et al. Neither the lubricant manufacturer or the automotive manufacturer have any obligation.
Since 2004 or 2005 we've seen how CI-4+ and CJ-4 oils won't kill a PD cam, and may actually be better than 505.01. This is not news to anyone here. AMO is similar to the old Delvac 1 and CI-4+ TDT.
Old June 6th, 2011, 08:04   #1560
TooSlick
TDI(s): Audi 100S
Amsoils recommended product for the PD's is their 5w-40 European Formula, which uses a VW 502.00/505.01 additive chemistry. However as we've seen, a fair number of PD engines still wear out pre-maturely with these oils. Since the vast majority of PD engines are now out of warranty, it makes sense to try some of these HD diesel oils. I wouldn't characterize it as experimenting, due to the number of people already doing this with excellent long term results.
I've had excellent reports from users of the Amsoil 10w-40 in earlier TDI's going back over ten years. I fully expect it will work as well in the PD's, given it's physical/chemical properties (HT/HS viscosity, ZDDP level, low volatility, etc)
TS
Page generated in 0.21645 seconds with 11 queries
[Output: 139.96 Kb. compressed to 118.50 Kb. by saving 21.46 Kb. (15.33%)]
