Franko6
September 2016, New Offering! Improve your Connecting Rod Bearings with Polymer Moly Coatings
I have the ALH/AHU 50.6 H-beam 4340 rods that are accurately made by our design engineers at Molnar Technologies. The owner’s pedigree extends 45 years in connecting rod design and is well-known in his field of expertise. We also have contracted to have the 53.7mm connecting rod for the BHW, 140+ hp Pumpe Duese and Common Rail 2.0 liter TDI engine. The same quality and rod design as our 50.6 rod will be incorporated in the larger 2.0 liter, 53.7mm connecting rod.
The rod is finished with the ARP 3/8" bolts with assymetrical thread design. The Assymetrical thread design is 'The Best, From The Best'. The pitch of the thread allows the holding strength of the bolt's threads to be extended over more of the threads in the rod.
The big end is finish honed using the ARP bolts, installed and correctly torqued. The rod bolts should always remain with the same rod, as honed. The parting line is correctly manufactured, by relieving the sharp edge at the internal mating point between the rod and the cap. This is a nearly universal mistake made on about every single 4340 rod we have examined. Center-to-center, sizing, parallel and balance are the highest precision accuracy with the work performed on a Sunnen AG-800, accurate to .00005" (yes, that's 5 hundred thousandths!). Our goal is to have the best TDI rods that money can buy.
Our initial offering is $525 per set
We also will precisely balance your pistons to our rods for the best overall engine smoothness.
For our initial offering, the first 10 sets of rods we will perform rod/piston balancing, normally $80, as a free service.
We also can provide many of your performance mod upgrades, including oil galleyed pistons, cylinder head porting, upgrade cams, injector upgrades, turbos, cylinder head and block builds, South Bend clutch kits and more.
