TornadoRed
- Joined
- Aug 3, 2003
- Location
- West Des Moines (formerly St Paul)
- TDI
- 2003 Jetta TDI wagon, silver; 2003 Jetta TDI wagon, indigo blue; 2003 Golf GL 5-spd, red (PARTED); 2003 Golf GLS 5-spd, indigo blue (SOLD); 2003 Jetta TDI wagon, Candy White (SOLD)
Without dino juice? You'd better stick to dino and stay away from any biodiesel blend greater than B02 or maybe B05.kidd38s said:...I will admit there's been a closet enviromentalist living inside for awhile (although aware it might be a hoax, the s4 does have a terrapass, haha). Between the tdi's potential for both performance and long distances without dino juice...
For one thing, B05 has been the limit for warranty coverage since 2004 -- you will lose your warranty for fuel-related issues if you use any higher blend.
Secondly, take a look at how the diesel particulate filter (DPF) works in the new common-rail (CR) engine. Periodically, fuel is injected but not combusted in the cylinder head -- it passes through to the DPF and burns there and burns up the collected soot at the same time.
But uncombusted fuel has a tendency to stick to the upper surfaces of the cylinder linings and can be scraped down into the lower parts of the engine, where it mixes with the engine oil.
Dino diesel, ultra-low-sulfur diesel (ULSD), when it contaminates engine oil is not good, but most oils still work fine with a certain amount of fuel contamination. Biodiesel is worse than dino. And fuel contamination is likely to be higher in the CR engines than in the earlier engines.
So anyone considering the use of high blends of biodiesel MUST plan on very frequent oil changes. Considering that the required motor oils are around $7/liter, then figure on around $35 for each oil change leaving a little bit for topping up. If you're running biodiesel, instead of 5k-10k-20k-30k mile oil change intervals (OCI), you might be looking at 3k-6k-10k-15k-20k-25k miles OCI. Or maybe even more frequently... used-oil analysis (UOA) will let you know.
Your best bet for long engine life is to avoid biodiesel entirely in the CR engines. Otherwise you are looking at frequent and expensive oil changes.
I wonder if anyone planning on going for a test drive can see if there's an owners' manual in the glovebox. If so, see what VW is saying about biodiesel -- there should be additional warnings beyond what was said in previous manuals.
