maroonfrog1
Over 115k miles on my 2011 S-Line A3 now and there are maddeningly frustrating things crapping out now.
Passenger door window electric up/down switch does not work from that door, but works if I run my switch from drivers side. Is this an easy fix?
Reason for posting, however, is to check in with this savvy group to ask about how to possibly get into the shifter console area to rebuild the connection frame where the 12vdc cigarette charger ports and aux audio port point towards the sky for plug-in. All three are now not working, and it looks as if the panel has cracked beneath the plastic such that nothing plugged in will engage fully. Must I disassemble this whole darned thing to get at the guts or is there a poor-man's workaround?
Thanks!
Thanks!
