GTADoum
Hello everyone,
I'll try to make my story short
After doing a silly mistake on my timing belt change, I blew out my head. So I got a "new" rebuilt one, installed a new timing belt and new injectors, 'cause the old ones were all plugged out. I had the new injectors checked before installing just to be sure they were ok.
The motor now starts easier than before, runs well and idle well, but only when the car is stationary ! When the car is moving slowly, and I let the motor idle, it is rather rough !! And as soon as the car comes to a complete stop, idle gets back to normal and very regular. No codes in OBD.
Anyone has any idea were I could check to pinpoint the source of this problem ?
Also, I don't know if it's related, but I wanted to reset the readiness codes by doing the procedure written in the big red book. All codes resetted to 0 except bit 4, which stayed at 1 ! What does that bit stands for ? Any tricks so that it would reset ? Maybe I'm doing something wrong in the reset procedure ? I'm doing the on-road reset procedure, since I didn't figure out how to reset those codes with Vag-Com.
Dominic
Dominic
