OP wants numbers, guessing he'd like to pay to have it replaced.I have a 2006 Jetta Diesel the rear main seal is leaking pretty bad, about how much $$$ is it to have it replaced ?? The car itself has about 265,000 Miles on it, it is the only thing wrong with it.
700 in labor, $100 part, So what? $200 in shop rags and degreaser?No that is $700 labor. Include parts and such and it is easily a $1k to $1.5k job, if OH does it. Of course we have no idea where the OP is so OH may not be handy. Other may charge more or less as well.
Yes, it is an advantage being able to repair my own cars, both as a hobby, and as a means to own higher priced/maintenance costly cars (Porsches, BMWs in the past), and not have the resulting expensive maintenance.Financially foolish not to replace worn parts when into something that deep. Who would want to pay $700 to replace the rear main seal and then another $1500 or more really soon for the contaminated clutch? Got to give it to tactdi for going the extra mile and doing the valve covers as well. This is the kind of thing you do when you do your own work and are proactive. Always doing the minimum means you are always working on your car, or broke down.
As a non professional we learn things this way. I have redone jobs 3 or more times as I found out I missed something or could of replaced something else needed while there or just flat out assembled it wrong. But I have yet to just stick known contaminated used up parts back in there thinking they will do just fine. The OP's clutch has to show signs of wear and contamination. When doing these kinds of jobs that involve a lot of labor I try and research everything I could possibly need to do a complete and thorough job.Yes, it is an advantage being able to repair my own cars, both as a hobby, and as a means to own higher priced/maintenance costly cars (Porsches, BMWs in the past), and not have the resulting expensive maintenance.
The downside is that I am not a professional, and have not seen everything. If I had known better at the time, I would have replaced the RMS when I replaced the transmission, it looked bad at that time, but I thought the mess was from the leaking transmission. That oversight did cost me a new clutch 1 year later. BUT, over the years, I am so many dollars ahead doing my own work, I can take the occasional hit of redoing a job.
