npdimonte
I finally completed my TB change, engine started right up and ran for about 2 minutes and then it died. I replaced the fuel filter as part of the TB change, but forgot to add fuel to the new filter. I have loosened the 4th injector line to help purge the air, but it hasn't helped.
Did I screw up by not putting fuel in the fuel filter?
Is there something that I may have disconnected that would disable the fuel pump during my TB change?
How do I test my fuel pump? My Bentley manual only talks about gas systems.
I disconnected the supply line to the fuel filter, turned on ignition switch to run position, but saw no fuel come out. Is this a problem?
How do I purge air out of this system?
Thanks in advance,
Nick D.
Thanks in advance,
Nick D.
