I would like to use anti-seize on lower control arm ancor bolts.
Specs confirms 52lbs-ft + 1/4 turn.
What about if lubricated with anti-seize?
Last 1/4 turn becomes not applicable?
Thanks for debating this with me.
Are you installing new bolts? If reusing the bolt, the torque & rotation specs are meaningless.
My guess - and that is all it is - would be to reduce the torque value and keep the 1/4 turn. The anti seize will reduce the friction so would require a lower torque value to reach the same clamping force. The rotation value after that should remain the same regardless of lubricant.
This chart may help.
If you are not using a new genuine VW bolt, haven't chased the threads with the proper chasing tap, are not using a good quality and recently calibrated torque wrench with the exact lubricant VW recommends including under the bolt head, it probably doesn't make
that much difference. My guess is more than one of these cars is running around with a reused TTY bolt installed good 'n tight with no issues. Yes you
should always replace them, but I bet more mechanics reuse TTY bolts than replace. And once it has been torqued and rotated (stretched), the original tightening specs are no longer applicable.
