frankie m
About 2 months ago I had the bodyshop replace 2 fenders which were starting to rust. When I got the car back, the door ajar light on the dash would stay on intermittently - I turned off the interior lights.
Still have not had a chance to return to the body shop to fix the issue- which is probably wires or a switch in the door?
Last week just as I returned home with AC on, the battery light came on and volts dropped to 12 volts. I have a Scangauge. A few hours later I started the car and volts were back up to 14.
I used my Sears multi-meter to check the battery- off its over 12 volts.
When i start the car volts are 14.
Then on 2 occasions I disconnected the negative terminal as car was on - the first time, car stayed running, the 2nd time, the car died.
Everytime I turn the AC on. after a few minutes the battery light will come on.
Im afraid to drive the car.
Soon I will use my mechanic/brother-in-laws meter to check if the alternator is charging.
Do u think the 2 problems - 1 fenders changed causing door ajar light to stay on intermittently AND 2 battery light on are related?
Frank
Frank
