DIY - How to Rebuild Bosch Starter Electrical Section (SR0408X) 0 001 125 012
****Thread DIY Under Construction****
There are right ups on how to remove & install the starter on the MKIV cars so please find those if you need assistance with that. This is strictly for rebuilding the Bosch 012 series starter.
I located my parts on ebay but I also noticed several other places, including my local starter rebuilding shop that could supply me with parts. I ended up spending $31 on the solenoid, brush box and rotor bushings. I also found that the solenoid for the Bosch 010 series starters is the same as the 012 series starters. This was much better than paying someone to rebuild it or going to a parts store for a reman unit.
The starting RPM on my starter went from 231 RPM to 357 RPM with what I did here. I also noticed that the nuisance jerking of my engine on start-up went away.
• Parts (search for parts using 0 001 125 012 Bosch)
o Rotor Bushing - Cap End (ID: 0.393” ; OD: 0.554”)
o Rotor Bushing – Planetary End (ID: 0.313” ; OD: 0.438”)
o Brush Box (AS SBH0014)
o Solenoid (DTS 77-27519)
• Tools
o Small Hammer
o Small Flat Blade Screwdriver
o Vice Grips
o Tap that will thread into 0.313” ID bushing
o Impact Driver with Philips Bit
o Scotch Bright Pad
o Vice
o 8mm wrench or socket w/ ratchet
o 13mm wrench or socket w/ratchet
o High Temp Grease
o Electrical Contact Cleaner
o Compressed Air
o Black Paint
1. Remove the nut & lock washer that hold the conductor strap from the brush box to the solenoid. After the nut and washer are removed the strap can be pulled off the stud on the solenoid.
2. Remove the three screws mounting the solenoid to the starter casing. These are philips heads and I found are easiest to remove with an impact driver to prevent from stripping the heads on them. After the screws are removed the solenoid body will come off easily (the spring in the picture is loose). Note that the plunger will not come off with the solenoid body and has to be disengaged from the engagement lever in the housing by pushing the catch of the plunger to the outside of the starter housing and then wiggling the plunger until the catch slips past the lever.
3. Remove the two bolts on the starter cap. They are several inches long. (Do not remove the two philips head screws on the cap as this will save a headache from occurring) Once the bolts are removed, separate the stator housing from the casted aluminum starter housing. The end of the stator/rotor will be visible now as well as the planetary gear set on the cast starter housing.
• Tools
o Small Hammer
o Vice Grips
o Scotch Bright Pad
o Vice
o High Temp Grease
o Compressed Air
o Black Paint
