michaelsquid
I ran a diagnostic for my TDI.
It has been intermittently going into this strange issue where it will act as if it is either stuck in a gear, or never shifts out of first.
The RPMs at 60 MPH is at 3,000 and 80 MPH is around 4,000.
This is not normal no matter what search you do, because the car goes back to normal and shifts fine, and 60 MPH reads at just a sliver above 2,000.
I have video of both instances where it is not shifting and will rev all the way to red-line if you allow it, and where it happily sits at around 2K at 60 and so on.
I have done an EGR delete so that code or reading is not of my concern, tuning is needed but since I don't know of any places in Texas I am at a bit of a loss for now. Any suggestions in my area?
Since the engine control module seems to be "hitting" in multiple sector scans is it possible that my issue lies with that module? Any way to diagnose it?
Funny how I had purchased a 2000 VW Golf 2.0L Gas that a week later suffered the same symptoms, and still currently is.
I will separate the reading for his vehicle with a long series of triple banded dashes. Also note the differing names and VINs.
Thank you solemnly!
Vag-Com results:
Monday,26,June,2017,20:17:23:07969
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWBF21J6YW605434 License Plate:
Mileage: 343290km-213310mi Repair Order:
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 343290km-213310miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 BD
Component: 1,9l R4 EDC G000AG 2507
Coding: 00001
Shop #: WSC 01317
VCID: 53AE823BA1EA69D904-4AE6
1 Fault Found:
19586 - EGR System
P3130 - 35-10 - Regulation Range Exceeded - Intermittent
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 HK
Component: AG4 Getriebe 01M 4606
Coding: 00000
Shop #: WSC 00000
VCID: 00047D77001C2241E9-095C
5 Faults Found:
00518 - Throttle Position Sensor (G69)
16-10 - Signal Outside Specifications - Intermittent
00660 - Kickdown Switch or Throttle Position Sensor
27-10 - Implausible Signal - Intermittent
00529 - Engine Speed Signal Missing
35-10 - - - Intermittent
00545 - Engine-Transmission Electrical Connection
31-10 - Open or Short to Ground - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 01317
VCID: 3E78C38F3A6894B1DB-4AE6
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 09 AIRBAG VW5 0003
Coding: 12345
Shop #: WSC 01317
VCID: 356ADCA30F5E57E90A-4AE6
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 900 M
Component: A4-KOMBIINSTR. VDO V24
Coding: 07242
Shop #: WSC 01317
VCID: 2C5CF9C7DC14162165-5120
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0X2124965
IMMO-IDENTNR: VWZ7Z0X2124965
1 Fault Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway KCAN 0001
Coding: 00007
Shop #: WSC 01317
VCID: 70E42DB730BC32C119-5102
1 Fault Found:
Address 35: Centr. Locks Labels: 1C0-962-258-II.lbl
Part No: 1C0 962 258 P
Component: 06 Zentr.Verriegel. 0001
Coding: 00256
Shop #: WSC 01317
VCID: 346CE1A704244EE13D-4B32
End-------------------------(Elapsed Time: 04:59)--------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 35: DTCs cleared
EDC15-16 Mileage: 342163 km 212610 miles
key=6>START OF 2000 VW GOLF 2.0L GAS
Monday,26,June,2017,21:21:29:07969
www.Ross-Tech.com
VIN: WVWGA21J0YW106438 License Plate:
Mileage: 212320km-131929mi Repair Order:
76
Mileage: 212320km-131929miles
Address 01: Engine Labels: 06A-906-018-AEG.lbl
Part No: 06A 906 018 JL
Component: 2.0l R4/2V MOTR AT V01
Coding: 00033
Shop #: WSC 05074
VCID: 75EA1CA34FDE17E9CA-4AE6
Readiness: 0000 0100
Part No: 01M 927 733 HM
Component: AG4 Getriebe 01M 4451
Coding: 00000
Shop #: WSC 00000
VCID: 0200777F0E103051FF-095A
4 Faults Found:
35-00 - -
31-00 - Open or Short to Ground
Coding: 03504
Shop #: WSC 01317
Component: Z9 AIRBAG VW5 0003
Coding: 23097
Shop #: WSC 01317
3 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance Too High - Intermittent
01218 - Side Airbag Igniter; Passenger Side (N200)
Part No: 1J0 920 900 K
Component: A4-KOMBIINSTR. VDO V13
Coding: 07242
Shop #: WSC 01317
VCID: 2A50FFDFD6E0081197-5102
Component: IDENTNR: VWZ7Z0X1577901
IMMO-IDENTNR: VWZ7Z0X1577901
2 Faults Found:
01315 - Transmission Control Module
Coding: 00007
Shop #: WSC 01317
2 Faults Found:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 60 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 01317
VCID: 06086B6F22380C71D3-4AE6
Subsystem 1 - Part No: Steuerger
Component: t Fahr. antwortet nicht
Subsystem 2 - Part No: 1J1959802D
Component: 61 Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 60 Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 60 Tõrsteuerger. HR0002r
5 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
01331 - Door Control Module; Driver Side (J386)
49-00 - No Communications
01131 - Control Circuit for Turn Signals
00933 - Electric Window Motor; Passenger Side (V148)
62-00 - No or Incorrect Adjustment
00934 - Electric Window Motor; Rear Left (V26)
62-10 - No or Incorrect Adjustment - Intermittent
End-------------------------(Elapsed Time: 05:04)--------------------------
Thank you solemnly!
Vag-Com results:
www.Ross-Tech.com
76
Coding: 00001
Shop #: WSC 01317
1 Fault Found:
19586 - EGR System
Coding: 00000
Shop #: WSC 00000
5 Faults Found:
Coding: 03504
Shop #: WSC 01317
Coding: 12345
Shop #: WSC 01317
Coding: 07242
Shop #: WSC 01317
1 Fault Found:
Coding: 00007
Shop #: WSC 01317
1 Fault Found:
Coding: 00256
Shop #: WSC 01317
www.Ross-Tech.com
76
Coding: 00033
Shop #: WSC 05074
Coding: 00000
Shop #: WSC 00000
4 Faults Found:
35-00 - -
Coding: 03504
Shop #: WSC 01317
Coding: 23097
Shop #: WSC 01317
3 Faults Found:
Coding: 07242
Shop #: WSC 01317
2 Faults Found:
Coding: 00007
Shop #: WSC 01317
2 Faults Found:
Coding: 04096
Shop #: WSC 01317
5 Faults Found:
