BrownCWJ
The pedal is currently not connected; I removed the slave cylinder from the bell housing to eliminate that as a potential issue.
When I start the car, I can shift freely between gears, and the axles will rotate appropriately as I put it in gear, and they will stop as I go back into neutral.
I'm fairly certain the pressure plate is aligned correctly, too.
Is it possible that I shifted the clutch disc during installation both times? That doesn't seem too logical, as I used the centering tool (and the splines on the input shaft would have to line up with disk)?
