Old January 22nd, 2009, 10:51   #3751
KROUT
persona non grata
Installed my 03 gti seats I had in my golf into my bug. I have riccaros for the golf.
old seats
Installed
Here is the door panel I sanded and repainted the top part and door handle. Still have to do the other 3 panels
Has any one ever tried to retrofit golf rear seats into a bug. I have the matching rear seats for these but the mounts are different in the bug for the rears. These seats are some much more comfortable than the old worn out ones I took out.
KROUT is offline   Reply With Quote
Old January 22nd, 2009, 17:31   #3752
Richard55
Richard55's Avatar
TDI(s): 2000 NB
Fuel Economy: 52 MPG
Scott
Did they bolt right up or did you have to modify?
"Speed cost money, how fast do you want to go."
RC6, 11 mm IP, 17/22, egr delete, 3 inch exhaust, 2.5" custom lower IC pipe, lift pump, "LurkerMike" custom DP, PP764, MAF deleted, 3 bar MAP, stage 2-14 lbs flywheel and clutch assy. Autometer Colbalt 2 Oil Pressure, Boost and EGT guages. K&N air filter. 18" Motegi wheels. vent and snowectomies. 55 watt HIDs
Richard55 is offline   Reply With Quote
Old January 22nd, 2009, 17:59   #3753
BrianCT
TDI(s): TDI
Nice. Did you cover the rears too? The head rests are the best mod for a Golf or Jetta, but seeing you're installing these in a Beetle to begin with ...then there's no argument over whether or not these actually look in "place" for a NB or not... lol.
BrianCT
P.S. nice interior Krout.
sent from an iThong™
BrianCT is offline   Reply With Quote
Old January 22nd, 2009, 19:03   #3754
delvi__acevedo
Mod'aholic
delvi__acevedo's Avatar
2 days ago pick up an other diesel a bit larger
can I upgrade this turbo
2015 BMW X5 35d Msport
2015 BMW 535dx Msport
delvi__acevedo is offline   Reply With Quote
Old January 22nd, 2009, 19:05   #3755
PeeWee
PeeWee's Avatar
Got my Rosstech Vagcom today and hooked it up. Nice to know what's going on even its nothing.
Peter
2005 MK 4 Wagon Shadow Blue
HID, GLI lip and side skirts, RXII and Borbet E5, Hidden Hitch, Defender Skid Plate, QLoader, Vagcom 2.0 BKD
PeeWee is offline   Reply With Quote
Old January 22nd, 2009, 19:09   #3756
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
last pic shows what oil we should be using in our ALH's
Also I did cold weather/fuel sender mod.I'll see if it does anything on Sat. when temps go back down to double -'s
2016 Jeep Wrangler, no longer do I have a diesel, repair manuals or spare parts sorry.
JASONP is offline   Reply With Quote
Old January 22nd, 2009, 19:14   #3757
oldpoopie
oldpoopie's Avatar
Delvi, are you serious or is this a joke? What are you doing with a truck like this?
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old January 22nd, 2009, 19:38   #3758
delvi__acevedo
Mod'aholic
no joke, Im hoping to be working by next week
Old January 22nd, 2009, 20:31   #3759
87turboquattro
TDI(s): 97 passat
Fuel Economy: 42-46mpg city,52-62mpg hwy
so when do you plan to mod your car.
87turboquattro is offline   Reply With Quote
Old January 22nd, 2009, 20:34   #3760
delvi__acevedo
Mod'aholic
no time anymore Bill
and the new vehicle already has 500Hp
Old January 22nd, 2009, 20:39   #3761
LNXGUY
LNXGUY's Avatar
How much boost does that badboy put out?
Bill
LNXGUY is offline   Reply With Quote
Old January 22nd, 2009, 22:03   #3762
kgirlbug2k
TDI? Nada. 2.0? prayed. No heat unless its under a load, won't go past 70 uphill...cell on, and can't pull codes until dawn.
"Monty" 1998 Silver Arrow NB TDI 179K, (Stock manual)
"Rodney" 2000 Uni Black NB 2.0, 200K 5/18/2009 (01M)
"Electra" 2001 Silver Arrow NB, TDI 170K (got the swap) Died 10/24/09
kgirlbug2k is offline   Reply With Quote
Old January 22nd, 2009, 22:39   #3763
SBAtdijetta
SBAtdijetta's Avatar
Fuel Economy: Best 51.4mpg, AVG 38+ and climbing
Yea you could go bigger on the turbo... but how you know it is not big enough... if you can still lift it without help... lol
10 Jetta TDI 6spd Cup - Tune, Turbo back Exh, BBS, etc
02 Jetta TDI Auto beater - Stock - Soon to be for sale
06 Jetta TDI 5spd - VNT2556,PD150 Injectors,3"TB,Pelq.,etc., Never dynoed in final config. - Sold
Need help? I have VAG-COM
SBAtdijetta is offline   Reply With Quote
Old January 23rd, 2009, 00:15   #3764
tothemax
tothemax's Avatar
How loud is that horn? much more than OEM?
Originally Posted by Honeydew
Installed a Stebel Nautilus horn. One of the OE brackets worked well after I bent it up. The threads on the bracket match the threads on the Stebel mounting bolt. The bracket is attached to the front bolt for the Panzer plate post.
tothemax is offline   Reply With Quote
Old January 23rd, 2009, 01:48   #3765
delvi__acevedo
Mod'aholic
I don't have a boost gauge, but my friend has one on a Detroit S60 engine and it does not seen to pass 20psi.
Page generated in 0.33499 seconds with 10 queries
[Output: 134.48 Kb. compressed to 112.44 Kb. by saving 22.04 Kb. (16.39%)]
