Old January 20th, 2018, 09:41   #18736
red16vdub
red16vdub's Avatar
Default What did you do to your car today?
I re swap Ecu's, replacing my rc4+ for what I thought was dead asv-rc5+ . Also I had 2 bad Bosch glow plugs, so I decided to replace all 4 with Beru units which I've always had better cold starts with anyways. I'm surprised the Bosch only lasted 2-1/2 years smh.
Bajan
Mk1 Gti /scIROCco 16v /A6 quattro sport / Mk4 TDI JSW 5spd
17/56 turbo, RC ASV-5+ @ 28psi, 3 Bar Map, 11mm IP, PD Lift Pump, R520's, McNally boost/egt, Euro FIS full screen Cluster, PD 150 Intake/racepipe, PD 150 plastic T.I.P + R32 maf air mods, Kerma 2.5" Fmic, Kerma 3"T-B exhaust/resonator/ Aero turbine muffler, SBC stage 3 Endurance, GLi brakes F/R , GLi axles, H&R Bilstein sports cup kit.
red16vdub is offline   Reply With Quote
Old January 25th, 2018, 09:51   #18737
Powder Hound
Powder Hound's Avatar
Chipped out of the ice so I could go to the gym. Silly weather we're having up here - I'll be glad when I move.
Cheers,
PH
Old January 25th, 2018, 13:45   #18738
romad
romad's Avatar
Cheers,
PH
To where are you moving?
The fleet:
romad is offline   Reply With Quote
Old January 27th, 2018, 08:23   #18739
Powder Hound
Florida is the plan, so we're trading months of sub-zero weather and frozen pipes for the possibility of the occasional hurricane and the guarantee of bugs that are big and populous sufficient to carry you away and eat you elsewhere. Gotta sell the house first, and gotta do some painting and other repairs before that will fly.
Sigh...
PH
Old January 27th, 2018, 14:05   #18740
romad
romad's Avatar
Sigh...
PH
That is what we're doing here except we are going to Prescott, AZ. The plan is to sell this house, rent while looking, then after buying do any renovations before moving in. We were going to paint after removing the wallpaper but decided to leave it white and let the new owners paint their preference.
Gotta figure how to get 3 cars to AZ AND which one will be parked outside! It'll probably stay the Jetta.
The fleet:
Old January 27th, 2018, 14:26   #18741
dandywriter
Adapted the sunroof which got seriously out of phase with the switch somehow (first time in 12 years).
2006 Jetta TDI 5-sp, Bosal hitch, frostheater, evo skidplate, upgraded rear springs and front spring dist kit (1" lift), GIAC Stg 1 tune, USA Spec iPod adapter, SMF clutch, Coolant Heater Grill Outlet, winter front, LED backup and lic lights, VCDS
dandywriter is offline   Reply With Quote
Old January 30th, 2018, 04:02   #18742
Powder Hound
Ha! If I were going back to AZ, that is probably where I'd end up. Unfortunately for me, the wife insists on proximity to the ocean. Prescott gives you tolerable summer temps (why the first capital was there) and in winter, an occasional dusting of snow is about all you'll have to put up with. Unless there is a 3 foot blizzard in Flagstaff that bleeds south that is...
And we have the same how-to-move-3-cars problem!
Cheers,
PH
Old January 30th, 2018, 04:35   #18743
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Ha! ... snip...
Car transport-haulers?
... cost = approx $1.25 per mile
... 45-50 years ago rent a u-haul bumper hitch ~~ $15-20 (?)
... In my 1966 Chevy SS (327) I hauled my BILs VW across 3 states at 65-70 MPH
... HIS VW HAD A BLOWN ENGINE
2015vwgolfdiesel is offline   Reply With Quote
Old January 30th, 2018, 08:45   #18744
romad
romad's Avatar
Cheers,
PH
That is why I chose it - out of the triple digit heat (had enough of it here in Oroville) and out of the snow area.
As for the cars, it would work if I could fly from Prescott to Oroville rather than drive to Phoenix, fly to Sacramento, drive to Oroville so I could get the third car. At least you also have the Auto-train option back east.
The fleet:
Old January 30th, 2018, 18:15   #18745
Todd13
TDI(s): 03 golf tdi
Dropped a another good bit of money, replacing my injection pump today...
Todd13 is offline   Reply With Quote
Old February 1st, 2018, 10:40   #18746
Powder Hound
I really think my cheapest option is fly one way and drive the other. I can do one in a weekend that way. Any shipping option I have seen is more than the car is worth.
PH
Old February 1st, 2018, 12:37   #18747
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
and
Fixmy59bug is offline   Reply With Quote
Old February 1st, 2018, 20:39   #18748
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Went out and started my car tonight after work, went back inside to let it warm up. Came out ~30 min later, car was cold.
Scangauge was up at ~165F, ice cold air coming out of the floor vents. Left my hand down at the vent and revved the engine to ~1500 RPM and suddenly lots of heat. Brought it back down to idle and the heat didn't go away or cool off even after ~60 seconds with the fan on 3, if anything it kept getting warmer (and scangauge lost 5+ degrees).
Everything else is relatively normal. Had this happen at least one other time this winter. Other times it warms up just fine (as fine as can be expected for a TDI ).
Coolant level is fine, just under mid way on coolant reservoir ball.
Thoughts?
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old February 2nd, 2018, 07:53   #18749
romad
romad's Avatar
Thoughts?
Collapsed hose on heater core? Reving the engine increased the coolant pressure temporarily opening the hose could account for the sudden heat.
The fleet:
Old February 3rd, 2018, 15:34   #18750
narongc73
Thoughts?
You warm your car up for half an hour? Talk about waste and not good for the car. Get a webasto
narongc73 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Page generated in 0.31139 seconds with 10 queries
[Output: 138.71 Kb. compressed to 117.00 Kb. by saving 21.71 Kb. (15.65%)]
