Old February 21st, 2017, 09:11   #18601
dogdots
dogdots's Avatar
TDI(s): None
Originally Posted by dogdots View Post
Not today but yesterday...I killed my 2002 hot rod Jetta I bought new
Driving along at 80 mph,100 miles from home, car had a slight stumble for a second, then ran normally for another 2 miles, then lost all power, engine died, and I coasted to a stop near an exit with a wide shoulder. Popped timing cover, belt is tight. Engine locked solid. White smoke from tailpipe as the engine died.
Rescued it from the side of the road after completing my work day and towed it to the shop. Luckily had a coworker just behind me that gave me a ride to where we were going, and was able to work the whole day at the account.
Not sure which direction I will be going, may repair or may part out and crush or sell as is. I got over 335k miles out of it with 235k being on a 28psi tune so it owes me nothing
Did exploratory procedure and found carnage in cylinder 2, broken glow plug tip and melted down piston, must have been a streaming injector. It doesn't look like I will be tearing this long block down, I may source a used ALH long block to replace it with.
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, both white, 1999 Superduty 7.3 ZF 6 speed, 2007 BMW 328xi, 2003 Mini Cooper, 1977 MB 280SL, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old February 21st, 2017, 10:33   #18602
fruitcakesa
Fuel Economy: 40's
Chasing down the elusive rattle from the rear of the 04, I wrapped the lower shock mount bolt in tape.
I still need to get the proper diameter bolt.
2004 Jetta TDI wagon 5 speed 278k+ VNT 17 Kerma tune. new heater core
fruitcakesa is offline   Reply With Quote
Old February 26th, 2017, 13:03   #18603
TDiesel06
Fuel Economy: 42W-48
Wax on!
"No mistakes, only lessons"
TDiesel06 is offline   Reply With Quote
Old March 1st, 2017, 13:00   #18604
donDavide
donDavide's Avatar
Fuel Economy: 51/45/40
Rear shocks and springs, assembled struts to install Friday and change control arms and 5th gear for Jetta
2003 Jetta GLS TDi TTbushings
2005 Passat GLS TDI Wagon Stone Henge Gray
2007 Jeep Grand Cherokee CRD
donDavide is offline   Reply With Quote
Old March 15th, 2017, 21:35   #18605
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Something in the starting system on my Jetta has been slowly (and inconsistently) getting worse and today was the day that it just wouldn't go anymore. Had to have a co-worker pull start me in the parking lot at work tonight so I could go home .
Got home, left the car running so I could periodically warm up (it's 23F outside tonight) and pulled the starter out of my TT and put it in my Jetta. Took 2 hours - 1.5 hours to get the starter out of the TT and 0.5 hours to both remove and replace the starter in my Jetta. Charlie had those starter bolts TIGHT and there's a lot more stuff in the way on the TT.
It seemed to turn over faster (though the car was warm) with the "new" starter - I'll know for sure tomorrow morning when it's 14F outside.
Anyone have a good source for a MkIV 02M diesel starter? Not interested in F.L.A.P.S. C.R.A.P. - just want a good, high quality starter.
I know a good motor shop so rebuilding the OEM one is an option and I have plenty of time.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old March 16th, 2017, 20:20   #18606
romad
romad's Avatar
Ordered the upgraded battery cables from Innovative Wiring
There is a thread here
The fleet:
romad is offline   Reply With Quote
Old March 16th, 2017, 21:24   #18607
Fix_Until_Broke
14F this morning and it fired right off. Cranked over faster than it ever has. I cranked it over without waiting for the glow plugs today after work (~30F) and it fired on the 2nd revolution.
Now I just need to order a new starter.
romad has me thinking about those battery cables as well - given that it's my daily driver it's probably worth it.
Old March 20th, 2017, 06:54   #18608
Votblindub
Votblindub's Avatar
Last weekend: got my oil extractor from IDParts and used it to change the oil in the white jetta. Shoved the tube WAY in there. Got it stuck. Got it out. No worries. Stupid moment over.
Sprint 520 Nozzles, 2.5 inch catless mufflerless BuzzKen exhaust, Malone stage 3 chip, 01M, Frostheater Full details
Full details
FB page for wagon lovers I have VAGCOM/VCDS
Votblindub is offline   Reply With Quote
Old March 22nd, 2017, 10:33   #18609
red16vdub
red16vdub's Avatar
I'm not sure why people keep getting these tubes stuck. The easiest way is to match the length of the dipstick tube with the extraction tube. Mark with tape or sharpie, that way you can gauge how much your inserting. Easy and simple.
bajan
Mk1 Gti /scIROCco 16v /A6 quattro sport / Mk4 TDI JSW 5spd
17/56 turbo, RC ASV-5+ @ 28psi, 3 Bar Map, 11mm IP, PD Lift Pump, R520's, McNally boost/egt, Euro FIS full screen Cluster, PD 150 Intake/racepipe, PD 150 plastic T.I.P + R32 maf air mods, Kerma 2.5" Fmic, Kerma 3"T-B exhaust/resonator/ Aero turbine muffler, SBC stage 3 Endurance, GLi brakes F/R , GLi axles, H&R Bilstein sports cup kit.
red16vdub is offline   Reply With Quote
Old March 24th, 2017, 14:28   #18610
donDavide
donDavide's Avatar
I changed left front axle inner boot on my jetta.
Old March 24th, 2017, 14:29   #18611
donDavide
donDavide's Avatar
bajan
Just an FYI, Autohaus AZ has them cheap.
Old March 27th, 2017, 10:41   #18612
That Guy
That Guy's Avatar
Fuel Economy: City 42 Hyw 59 (Before and after upgrades)
- Cleaned the ground under the windshield
- Cleaned the cabin air filter. (And found a screwdriver laying next to it...thank you dealer.)
- readjusted the windshield washer nozzles
- Checked the ECU connection
- cleaned everything up before putting it all back together.
Quick question:
On the drivers side under the windshield there was a small plastic cylindrical device with two wires attached to one end. It's about the size of my thumb. Does anyone know what that is? A sensor of some type maybe.
Green 2001 Golf 1.9 TDI (A4 - ALH) (New June 2001)5 spd man, 151000 Km (Aug 2012), PP520 nozzles; SBC Stage 2 Endurance Clutch w/SMF; GT1749VB; Malone tune, Multiple upgrades.
Black 2009 GTI 2.0 TSI (New Dec 2009)6 spd dsg, 53000 Km (Apr 2012),stock
That Guy is offline   Reply With Quote
Old March 27th, 2017, 11:13   #18613
PeeWee
PeeWee's Avatar
If it's under the rain I tray it up is probably the glow plug relay
Peter
2005 MK 4 Wagon Shadow Blue
HID, GLI lip and side skirts, RXII and Borbet E5, Hidden Hitch, Defender Skid Plate, QLoader, Vagcom 2.0 BKD
PeeWee is offline   Reply With Quote
Old March 27th, 2017, 14:48   #18614
That Guy
That Guy's Avatar
Maybe, but I can't find any relay pictures that look like it.
I found a picture that shows it...see below. It's in the far right of the picture, clipped to the side.
It's plastic, black, cylindrical, and is very light weight.
PS: This is a picture of a MKIV, but is not of my car.
Old March 27th, 2017, 16:11   #18615
romad
romad's Avatar
The only pictures I see are in your sig.
The fleet:
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Page generated in 0.35281 seconds with 10 queries
[Output: 141.70 Kb. compressed to 119.78 Kb. by saving 21.92 Kb. (15.47%)]
