Old July 8th, 2015, 18:47   #18001
skully
I got my 1960's plates in the mail this week, but the white lettering on my TDIclub frame just didn't work so I had to fix that.
After one coat.
Two coats and an hour later.
Installed and sitting with the rest of the family.
2004 Jetta: TDtuning Stage 3 (17/22, Exhaust), LSD+3.16FD, Short Shift, Shine+Bilstein, HID Reps, FIS, Climatronic, Euro Recaros, Colt Cam, MFD
2013 GLI Autobahn w/nav: Rain/Light Sensor Mirror, Auto Headlamps (For Sale)
2014 BMW 328xd SportWagon: Stock! (For now)
skully is offline   Reply With Quote
Old July 8th, 2015, 19:55   #18002
romad
romad's Avatar
I still have the yellow on blue plates on my Miata that I got in 1989. The blue of the plate is an exact match for the blue on my Miata. Cranberry has Veteran plates.
The fleet:
romad is offline   Reply With Quote
Old July 9th, 2015, 13:54   #18003
skully
Those blue and yellow plates are pretty neat too. Too bad there weren't enough orders to make those too, but I guess that makes yours more exclusive.
Old July 9th, 2015, 19:53   #18004
dmoonen
dmoonen's Avatar
Engine and trans is pulled from the winter 05 Wagon Time for a refresh and rebuild and other things https://instagram.com/p/478TppFYs8/?taken-by=dmoonen
Dillen,
Bagged 04 R32 (VRT build), 08 Audi S4, 01 2.7TT swapped Audi TT Roadster, 94 Merc 500e.
VCDS, VAG TACHO, MB STAR MACHINE (WIS, DAS, STAR), MPPS++
dmoonen is offline   Reply With Quote
Old July 10th, 2015, 09:28   #18005
Caddy 16v
Caddy 16v's Avatar
Replaced the rear brakes, one slider was stuck, broke the damn thing off trying to get it free. Off to the wrecker for a new carrier I suppose.
2000 Jetta, mufflerectomy, Evolution Atlas skid plate, OEM xenon reps retrofitted, Hella Micro DE, HFLOX Warp 3 nozzles, 3 bar map, Malone Stage 5 Custom, Euro 17/22, DC Stage 4 clutch, STAGG suspension, Curt hitch, Auber EGT and NSP boost gauge, Hella Sharptones, Rally Armor mud flaps, 1.8T pancake pipe, upgraded SMIC, VAG-COM, all offroaded out
2000 Golf, JSP Armadillo skid plate, limo tint (Sold)
Caddy 16v is offline   Reply With Quote
Old July 11th, 2015, 13:33   #18006
Nuje
Fuel Economy: 1250km/tank
Changed the oil on the wagon. Added a half-bottle of ZDDP to keep the new head/camshaft all nice and happy.
Even though the car "lost" less than 1L of oil in the 13000km since the last oil change, there's a fair bit of oil on the outside of the intercooler. Maybe a bad hose connection? Micro-cracks in the intercooler?
Nuje is offline   Reply With Quote
Old July 12th, 2015, 10:33   #18007
smopoim86
Fuel Economy: 40+
Look where the front air shroud attaches. Mine rubbed some small holes in a couple of the core tubes.
smopoim86 is offline   Reply With Quote
Old July 13th, 2015, 18:08   #18008
brnsgrbr
brnsgrbr's Avatar
Fuel Economy: 44 mpg
Installed a solar pulse battery trickle charger to help with a parasitic drain I've had. I'll hunt it down before winter but this should help in the short term.
http://www.batterystuff.com/solar-chargers/SP-5.html
2.0Ltr ALH w/BHWs, WB girdle, IE Tuscan rods, RyanP GtB2260Vk kit, 4bar MAP; Kerma 3" exhaust w/HF cat & Aeroturbine 3030XL, headwork, DRW 6speed w/DG Sigma shifter;SBC S2 End race clutch W/ferramic disk; Peloquin TBD; Bosio Stage 2 R520s; DLI Technik mounts ; 11mm; TT CA bushings; DG Panzer FMJ, RP,& 100K TB&SB upgrade; Coolant heater; DRL & EGR deletes; ventectomy; Accuair/Airlift suspension;B20-B100
brnsgrbr is offline   Reply With Quote
Old July 13th, 2015, 18:43   #18009
Hyde7278
Hyde7278's Avatar
TDI(s): 2001 Golf GL
I have a few of the factory VW solar chargers. Wouldn't they have been the cheaper alternative ?
Hyde7278 is offline   Reply With Quote
Old July 13th, 2015, 19:55   #18010
brnsgrbr
brnsgrbr's Avatar
I wasn't even aware of their existence. Then after doing some research I decided I wanted to incorporate the de-sulphating technology. I also like that the mono crystal silicone power and efficiency ratings are so high.
How many watts is the VW version?
Old July 15th, 2015, 11:43   #18011
nokivasara
nokivasara's Avatar
Fuel Economy: 44-49 mpg
I put in an aux-adapter (with USB and SD card) to our stock radio, works really well.
It's in the glove box right now, but I think I will attach it hanging on the panel above the ash tray with some 3m tape. Just need to figure out how to route the wire...
I bought one of these:
http://www.ebay.co.uk/itm/AUX-Adapte...item19e387465f
nokivasara is offline   Reply With Quote
Old July 21st, 2015, 21:17   #18012
dmoonen
dmoonen's Avatar
I HAVE AC! Changed the AC clutch and blows ice cold. Removed the alternator and drained down the coolant and removed the center coolant pipe to give some extra room for the compressor lines and suspended the compressor with zipties and a bar. . all in took about 2 hours with never doing it before.
Prepped the 05 wagon for a cross country trek
  • Coolant flush and replaced with VW fluid
  • Replaced the battery
  • Changed the oil and filter with lubro moly 5w40
  • Flushed the break fluid
  • Changed the coolant bulb, fitting on the side was cracked
  • Changed AC clutch
  • Changed power steering fluid
  • Rotated the tires
  • Checked the breaks and bearings for play
  • Changed the cabin filter
  • Detailed the interior and exterior
  • Tested the lift pump-all good
  • Loaded the bike racks up
  • Cross bars and thule cargo box on
Ready to go!
Dillen,
Old July 22nd, 2015, 06:32   #18013
TDI_G
TDI_G's Avatar
Did quite a bit on the Golf over the past few days. I scored a set of spindles, calipers, carriers, etc off of a 1.8T Jetta at the salvage yard. Last Saturday I pressed in new OEM wheel bearings into the hubs and installed everything including the junkyard pads and rotors on Saturday since my new pads and rotors weren't in yet. Monday I drove out to Andrew Rodriguez's (fixmyvw.com) shop to pick up the pads and rotors and got them installed last night. I installed Fremax 288mm rotors and PowerStop Z26 Carbon/Ceramic Pads (http://www.fixmyvw.com/1-8t-vr6-288m...ic-brake-pads/). This is definitely a worthwhile upgrade.
I also flushed my brake fluid, changed my fuel filter, and changed my cabin air filter. Getting ready to take the car on a 750 mile trip up to Ohio to visit family.
TDI_G is offline   Reply With Quote
Old July 22nd, 2015, 19:25   #18014
ConvergenceFreak
Fuel Economy: 02J: 35 City/45 Hwy, 01M: 27 city/40 hwy when TCC actually worked. All on stock ECU
There's a first time for everything. Now that I live in a place with a driveway and we got a break in the heat and humidity….
Today I changed the oil, replaced the fuel filter, cabin filter and set the proper level of the 01m trans fluid.
I made some noob mistakes, but, thank to this forum, ID parts and YT videos I found my way through them.
This was all to save some $ on the 180k service because the car will go to my TDI guru next week for inspection and I am expecting will need a bit more, that I am not upto doing yet…
ConvergenceFreak is offline   Reply With Quote
Old July 26th, 2015, 12:12   #18015
fruitcakesa
Fuel Economy: 40's
New mirror lenses in the 02 thanks to the parts car
2004 Jetta TDI wagon 5 speed 278k+ VNT 17 Kerma tune. new heater core
fruitcakesa is offline   Reply With Quote
Page generated in 0.32213 seconds with 10 queries
[Output: 133.87 Kb. compressed to 112.40 Kb. by saving 21.48 Kb. (16.04%)]
