Old November 1st, 2014, 17:15   #17251
nkgagne
Fuel Economy: See Fuelly in signature
Swapped wheels over to winters and stuck the mud-flaps back on. Took some time and cleared out the space behind the front fender liners for the first time. Right side: Holy cow! Packed full of a good three pounds of heavy wet mud, but no visible corrosion. Left side: clean as a whistle. Just a few grains of sand. Can you say "strange"?
Bone stock. Dieselgate Stage 1 reflash complete.
nkgagne is offline   Reply With Quote
Old November 1st, 2014, 23:22   #17252
Nuje
Fuel Economy: 1200km/tank (Mk4); 750km/tank (Mk7)
Originally Posted by dremd View Post
I removed the OEM monsoon stereo and started replacing it with a pioneer NEX 4000.
I've got the steering wheel controls working, HD radio working, Bluetooth, butt that's about it so far.
Still left
Reverse camera
Long press steering wheel button for Siri
Update firmware for carplay
Mount the radio in the car
Mount USB/ aux in
Remove dead satellite radio.
Which car of yours is getting the NEX4000? If on your older Jetta, what's your plan for getting a Siri button on your steering wheel?
I have NEX5000 in my '03 wagon with MFSW and would like to rig that up as well.
Nuje is online now   Reply With Quote
Old November 2nd, 2014, 07:57   #17253
dremd
dremd's Avatar
I put it in the 03, 2014 is remaining stock other than the hitch for the foreseeable future.
My Metra axcess steering wheel controller can be programmed for long presses.
See page 10 of http://contentdocs.installernet.com/...duct/34201.pdf
I'm not sure that the NEX 4000 has anything that it will recognize as Siri though.
I'll keep you guys posted if it works.
I wish I could remember the designers name, super cool guy we met at sema in '12 I've got his card around here if something needs modifying.
2013 Nissan LEAF what are these emissions you speak of?
03 Silver Premium Jetta Wagon lots of OEM goodness. 1.8T Triptronic eliminated, ALH + 6 speed manual installed in place. Emissions? Yes, a lot
2006 Sprinter long range hauler, 300+ cubic feet loaded 25 mpg.
2014 JSW (Went back to VW) Emissions? Well, about that . . .
dremd is offline   Reply With Quote
Old November 2nd, 2014, 08:27   #17254
romad
romad's Avatar
Originally Posted by Killabee228 View Post
Installed puddle lights
Obviously they don't work — no puddles are there (unless you count the "puddles" OF light, that is)!
The fleet:
romad is offline   Reply With Quote
Old November 2nd, 2014, 08:34   #17255
Killabee228
Fuel Economy: 52mpg so far
Just.. Just wow... Mind blown.
Here's the kit.
http://www.uspmotorsports.com/RFB-LE...Light-Kit.html
But the coding is different then what they posted. With my mk6 all I had to do was check bit 6 in Byte 3. But the rear doors are controlled off of the front can bus. So you have to select the drop down box.
deAutokey Led foglights - Euro Switch - Malone Stage 3 - DieselDubs Downpipe with Res - CR170 Turbo - Aluminum Bumper Cover - 17" Anthracite Goals - Driver Gear Springs - Euro Cup Holder - Anthracite Plasti Dipped Front Emblem - Neuspeed Turbo Discharge Pipe - DarkSide Developments HP EGR Delete - MICRO-CAN VCDS owner
Killabee228 is offline   Reply With Quote
Old November 2nd, 2014, 08:47   #17256
romad
romad's Avatar
Here's the kit.
Looks like it is not for the MK IV models.
The fleet:
Old November 2nd, 2014, 13:24   #17257
Killabee228
No only for mk5 and 6
Old November 2nd, 2014, 18:28   #17258
Zedbra
Zedbra's Avatar
Replaced my cracked glass lenses with plastic ones, painted the inside of my lights, replaced my ballasts and bixenon bulbs - took almost all day but it needed to be done. In order to get to the lights on these older Dubs, you have to remove the whole front bumper. Fun.
Started like this:
Ended like this:
Time for beer(s).
2005 Jetta TDI GLS: VNT17VB, 3 Bar, Malone Stage 4, BiXenon retros, OEM Fogs, ST Coilovers, OZs
Zedbra is offline   Reply With Quote
Old November 2nd, 2014, 18:36   #17259
Smalls
In the process of putting a PD back together and reinstalling it into the car. Got a notification that my parts shipped from idparts.
Have spent WAYY to much cash there over the last few weeks...
Smalls is offline   Reply With Quote
Old November 3rd, 2014, 04:01   #17260
TDI Convert
TDI Convert's Avatar
Fuel Economy: See my signature for Fuelly data
Ended like this:
Time for beer(s).
Looks great! Love the dual turn signal mod. Where did you buy new plastic lenses from?
What projectors do you have installed?
2006 Jetta: PD150 Intake and Injectors, R783 Nozzles, GTB1749VC, TD Stg 3 Tune, 3 Bar Map, SB Stg 3 Clutch
TDI Convert is offline   Reply With Quote
Old November 3rd, 2014, 05:41   #17261
k2teddy
Hi Everyone, I searched the forum and couldn't find a thread relating to an issue that we're experiencing with our new 2015 Golf TDI.
Upon receiving the car brand new, a week an a half later, we open up the hood to check oil levels... and to our surprise, there was crystal build up in a section of the car.
We did some research online, and discovered that it could be an Adblue Leak. So we took the car back to the dealer and they held it for a few days, and replaced a part and said that it was indeed a leak. They seemed to emphasize the fact that it would have been dangerous to continue driving the car, and they were glad we brought it in to inspect/fix.
Upon receiving the car back, we drove around for a day, and notice the crystal build up AGAIN!! We are currently out of town, returning on Weds. So the car is now in the garage, untouched, with crystal build up for the next couple of days
Has anyone experienced this with their TDI? What is it exactly?? I want to make sure that the mechanics will target the problem and fix it once and for all!! IT's a waste of time and effort taking the car back to the dealership.
Thanks!
k2teddy is offline   Reply With Quote
Old November 3rd, 2014, 11:09   #17262
crashtested
crashtested's Avatar
Thanks!
Adblue? In a Golf?
I know I'm stuck back in 2010 but has this really happened?
MKVI -
OB ---
crashtested is offline   Reply With Quote
Old November 3rd, 2014, 13:30   #17263
MikeS_18
MikeS_18's Avatar
Drove to the local dealer and got two adblue 1/2 gallon dispensers for about $14 total.
Much better than the $25 that you end up paying any online retailer after shipping.
'03 Wagon, 5spd,17/22 turbo, RC3+, PP520s, Stage 1 clutch, Old Man Intake, Lift Pump, TT Short Shifter, EGR Cooler Deleted, 800 Mile/tank club
2013 Passat SE and a '64 Ford Econoline Travel Wagon, 200ci straight six, 3 spd, 17mpgs "If it's got a hood, it ain't no good!"
6 Garages?! It's still not enough!
MikeS_18 is offline   Reply With Quote
Old November 3rd, 2014, 13:49   #17264
k2teddy
Originally Posted by crashtested View Post
Adblue? In a Golf?
Yup, as part of the new 2015 model...
Old November 3rd, 2014, 17:29   #17265
MikeS_18
MikeS_18's Avatar
I just added the adblue to the passat. The extent to which the dealer got crystals all over the trunk area is now proven to be ridiculous. It's not that hard. Equate it to a gas jockey who get gas all over your fender cause he can;t put the hose in the hole. geez.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Page generated in 0.31711 seconds with 10 queries
[Output: 136.98 Kb. compressed to 115.57 Kb. by saving 21.41 Kb. (15.63%)]
