Old February 8th, 2018, 08:47   #18751
Nevada_TDI
Moved my IQ from 4.2 to 2.4 and my highway mileage improved.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Old February 8th, 2018, 09:16   #18752
You shouldn't tell anyone. It's not supposed to work that way.
2002 Jetta wagon, 373K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 259K; 2011 335d, 56K; 2015 Golf Sportwagen, 10K. Principal, http://www.idparts.com
Old February 8th, 2018, 19:42   #18753
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Originally Posted by narongc73 View Post
You warm your car up for half an hour? Talk about waste and not good for the car. Get a webasto
Can you explain what the waste is here?
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old February 8th, 2018, 22:24   #18754
romad
romad's Avatar
Probably the money you spent for the amount of fuel consumed in those 30 minutes? That would be about 75?
Of course, he could have meant the wear & tear on the engine.
The fleet:
romad is offline   Reply With Quote
Old February 9th, 2018, 05:31   #18755
Fix_Until_Broke
And the money spent running a webasto for the same period of time, not to mention the $3k they cost up front?
I'm not too worried about wear/tear on the engine by idling.
Old February 9th, 2018, 05:45   #18756
Brought the red Golf home today and it joined its newer companion:
It was hanging out in the warehouse (and a co-worker was driving it when her car died) but now that I have room in the garage it's safely tucked away.
Old February 9th, 2018, 08:45   #18757
Nevada_TDI
FUB, thank you for saying that; you are a well-respected member here and someone is always trying to say idling will prematurely kill a turbo. You do not seem to believe that rumor, and personally neither do I.
_______________
Old February 12th, 2018, 03:10   #18758
red16vdub
red16vdub's Avatar
I never understood why people spread misinformation, whereas the proof that idling isn't good or hurt the car. I've done it for years/decades especially in winter and never recall having a single issue. I will agree driving off after a minute or so, you'll get faster heat but other than that, I don't see a problem. I visit my son yesterday in Barnstead,NH. We sat in the car talking for several hours with it idling, I never shut the car till I got back home which was roughly 7 1/2 hours in total.
Bajan
Mk1 Gti /scIROCco 16v /A6 quattro sport / Mk4 TDI JSW 5spd
17/56 turbo, RC ASV-5+ @ 28psi, 3 Bar Map, 11mm IP, PD Lift Pump, R520's, McNally boost/egt, Euro FIS full screen Cluster, PD 150 Intake/racepipe, PD 150 plastic T.I.P + R32 maf air mods, Kerma 2.5" Fmic, Kerma 3"T-B exhaust/resonator/ Aero turbine muffler, SBC stage 3 Endurance, GLi brakes F/R , GLi axles, H&R Bilstein sports cup kit.
red16vdub is offline   Reply With Quote
Old February 13th, 2018, 12:33   #18759
CasaEd
TDI(s): VW Passat B4
Idling may not be so bad for your engine, certainly is a waste of fuel and definitely not good for the environment
CasaEd is offline   Reply With Quote
Old February 13th, 2018, 19:34   #18760
red16vdub
red16vdub's Avatar
Default What did you do to your car today?
Originally Posted by CasaEd View Post
Idling may not be so bad for your engine, certainly is a waste of fuel and definitely not good for the environment 😱
Lmfao, yes I waste a few cents here and there idling, but hey it’s my hard earned coins.
But Really ?
All of a sudden we pretend to care about the environmental impact of dirty diesels .
Hmmmm I doubt that.
Bajan
Old February 13th, 2018, 20:29   #18761
romad
romad's Avatar
...and definitely not good for the environment
In that case you need to immediately sell ALL of your Diesel and Gasoline fossil fuel using vehicles, and buy either a SmartforTwo Electric drive or a Fiat 500e.
The fleet:
Old March 21st, 2018, 18:04   #18762
kirktdi
Repaired blend door. 5 hour job turned into 7 hours. Success and well worth the $6 it cost me.
kirktdi is offline   Reply With Quote
Old March 24th, 2018, 18:17   #18763
Powder Hound
Powder Hound's Avatar
Fuel Economy: pretty freakin' good.
Had an inspection problem: both front fenders have rust holes. I had a passenger side white fender, but the driver's side was a surprise. But I did have a silver one, so now my Golf 4-dr is a ghetto car. Right now I'm toying with the idea of just buying 2 new fenders and having them painted before installing. Hmmmm.....
Cheers,
PH
Thinking outside the box is difficult for some. They're afraid they'll fall off the edge of the box and be lost to oblivion.
Powder Hound is offline   Reply With Quote
Old March 25th, 2018, 05:53   #18764
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
Cheers,
PH
Drive it gheto id say. Say the $. I like to talk about great ways to save money but rarely do i follow my own advice.
2015 Golf SEL. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old March 26th, 2018, 06:19   #18765
Powder Hound
It's going to be ghetto for a while. Too many other things on the burner to deal with it more than I have.
Page generated in 0.31842 seconds with 12 queries
[Output: 137.21 Kb. compressed to 115.56 Kb. by saving 21.65 Kb. (15.78%)]
