coulor of wires to wire function or porous cam
fluxcore
ma.
06 jetta tdi
sensor on 06 or 07 jetta tdi sensor is Napa echlin css1225Please thanks
Ol'Rattler
PNA
2006 BRM Jetta
Camshaft position sensor? What you posted is for a 2005 (probably a BEW engine) according to Napa. Trying to monkey rig it to make it work could damage your ECU.
A couple of options for your 2006 BRM engine.
https://www.idparts.com/camshaft-position-sensor-g40-oem-a5-brm-p-3142.html
https://www.europaparts.com/camshaft-position-sensor-03g957147b.html
Semi questionable (cheap), but might be OK per the fitment.
https://www.fcpeuro.com/products/vw-engine-camshaft-position-sensor-jetta-vag-03g957147b
Almost forgot. I don't have a wiring diagram for a BEW so IDK the answer to you question.
fluxcore
ma.
06 jetta tdi
only 1 plug not connected and it 2 wire, i cant find old cam sensor, vw dealer will sell me a 3 wire but on 3 wire connected?
