My Car: 2003 Jetta ALH TDI 200K miles Auto trans
The turbo blew on my car a while back so I replaced it with one I had on an engine sitting in the shop. The "new" turbo was a reman which was in a parts car I had purchased. I had driven the parts car to my house and the turbo didn't work well and I adjusted the control arm and it work
So anyways, I installed that reman turbo and it worked well for a while. Now for some reason when ever it is hot it wont boost. During the winter I had zero problems but heat seams to cause issues.
"How could that be? You're crazy" and you're probably right.
Well I went through this forum and dutifully tested and or replaced all the usual suspects. I replaced the vacuum lines, the turbo had a new vacuum actuator and I've adjusted and readjusted that bad boy according to specifications listed on TDIclub.
I went ahead and put in a new N75 and even changed all the little plastic pieces that connect all the vacuum lines.
I have even built a leak tester as per TDIclub suggestions and tested all the piping for leaks. Nada, Nothing, zilch. No leaks and everything works.
I have a VCDS cable and tested the car. I can show you the data but the short version is that my specified boost and manifold pressures never will match my actual pressures when under full throttle.
Here is an excerpt in Excel format of specified and actual Airmass:
410 400
420 380
415 380
410 380
415 380
485 375
340 420
355 385
375 380
370 375
530 350
570 410
545 435
850 465
850 450
850 455
850 460
850 460
850 455
850 465
850 475
850 490
850 500
755 510
745 515
705 570
710 500
710 495
Here is my specified and actual Boost
1060.8 1030.2
1050.6 1050.6
1050.6 1030.2
1050.6 1030.2
1071 1030.2
1050.6 1030.2
1162.8 1030.2
999.6 1060.8
999.6 1020
999.6 1009.8
999.6 999.6
1193.4 999.6
1234.2 1060.8
1234.2 1101.6
1948.2 1142.4
1948.2 1162.8
1948.2 1173
1948.2 1183.2
1948.2 1193.4
1948.2 1213.8
1948.2 1244.4
1948.2 1285.2
1948.2 1326
1683 1356.6
1540.2 1397.4
1489.2 1417.8
1479 1346.4
1479 1285.2
Both of these are taken from an idle to heavy acceleration. I can show other variations of my driving prowess but its all about the same.
Long story short: Why does my turbo only seem to work when its cold? What am I missing? Help.....
I am doing everything in my power to avoid having to plunk down money on a turbo...but I think that may be what happens next......
410 400
420 380
415 380
410 380
415 380
485 375
340 420
355 385
375 380
370 375
530 350
570 410
545 435
850 465
850 450
850 455
850 460
850 460
850 455
850 465
850 475
850 490
850 500
755 510
745 515
705 570
710 500
710 495
1060.8 1030.2
1050.6 1050.6
1050.6 1030.2
1050.6 1030.2
1071 1030.2
1050.6 1030.2
1162.8 1030.2
999.6 1060.8
999.6 1020
999.6 1009.8
999.6 999.6
1193.4 999.6
1234.2 1060.8
1234.2 1101.6
1948.2 1142.4
1948.2 1162.8
1948.2 1173
1948.2 1183.2
1948.2 1193.4
1948.2 1213.8
1948.2 1244.4
1948.2 1285.2
1948.2 1326
1683 1356.6
1540.2 1397.4
1489.2 1417.8
1479 1346.4
1479 1285.2
