mgapei
I have a 2006 Jetta with about 50K miles or 88K kilometers. the car was smashed lightly in the front and sat around for about 6 months outside. I have been driving it since fixing it for about 3 months now.
The car works great but I have three main problems all showing as faults when I scan. see below.
1.I replaced the MAF with a new one but still have the check engine light code.I also checked the EGR and could not see any noticeable problem.
I thought I had found the problem with a clamp on the air intake that was not in place but the same code returned after 25 miles or so.
2.I do not have my fans working and it appears that power is not coming to them. Harness is fine coming into the fans. Problem seems to be on the other side of the plug near the battery.
3. My other question is the code 01314 which is an engine control module fault. The ASR light ison all the time. I did flicker off on one drive but stayed on after a while.the ross tech site says "To clear this Fault Code you will need to correct the Problem in the Engine Control Module". How do you correct this type of problem?
I am wondering if these problems are related like a wiring issue?
Sorry for all these questions.Just starting to use the VCDS on my car and to figure things out. All help welcome.
Bob
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: VWZ7Z0E1676083
Coding: 0050071
Shop #: WSC 93229 999 00650
VCID: 63CF4027DBD3
2 Faults Found:
005697 - Please check DTC Memory of A/C Controller
P1641 - 000 - -
000257 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 000 - -
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 00066 000 00000
VCID: 3F87AC5717FB
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 EG
Component: Climatic PQ35 084 0404
Shop #: WSC 00000 000 00000
VCID: 6DDB261F0D17
2 Faults Found:
00898 - Control Circuit A/C compressor
010 - Open or Short to Plus
00819 - High Pressure Sensor (G65)
006 - Short to Plus
Bob
Coding: 0050071
VCID: 63CF4027DBD3
2 Faults Found:
P1641 - 000 - -
P0101 - 000 - -
Coding: 0017025
VCID: 3F87AC5717FB
1 Fault Found:
VCID: 6DDB261F0D17
2 Faults Found:
006 - Short to Plus
