S
SkyPup
Guest
The crankcase lubricant requirements of passenger car DI diesel engines are determined primarily by the VW TDI engine test. This test has an appetite for higher detergent formulations -to meet the current ACEA B4 limits for piston cleanliness and ring stick, oils are typically formulated to 1.3% wt-1.5% wt sulfated ash. The proposed ACEA B5, which will issue in 2001 as an addendum to the ACEA 98 sequences, sets even higher performance for piston cleanliness, requiring a piston merit 5 points higher than the existing ACEA B4.
Currently, ACEA, VW and DC define the performance of lubricants in passenger car diesel engines as follows:
ACEA B1-98 Fuel economy (HTHS < 3.5 cP)
ACEA B2-98 General purpose (HTHS > 3.5 cP)
ACEA B3-98 High performance (HTHS > 3.5 cP)
ACEA B4-98 High performance DI diesel (HTHS 3.5 cP)
ACEA B5 (addendum to 98) High performance DI diesel plus fuel economy (HTHS < 3.5 cP)
VW 505.00 / 505.01 / 506.00 / 506.01 Formulation specific VW approvals
MB 229.1 / 229.3 / 229.5 Formulation specific approvals
In the future, the use of oxidation catalysts and particulate traps will be required to meet the ever-more stringent CO, HC, NOx and particulates emissions limits. Catalyst protection and durability will be the major issue facing OEMs. This is likely to have a dramatic impact on lubricant formulations, with increasing demands for lower levels of sulfur, phosphorus, and sulfated ash.
The new E5 oil test sequence required the development of a number of new tests, as summarized below:
Extending the existing CEC OM 441LA test method to include a parameter to measure deposits in the turbocharger compressor
Developing an oxidation test to address problems with bearing corrosion and piston undercrown deposits
Investigating the issues of lubricant compatibility with exhaust gas recirculation (EGR)
Investigating the feasibility of a lubricant fuel efficiency test
The following summarizes the changes that were made to limits on existing tests, and the new tests added, for
ACEA E5:
OM 441LA to MB 228.3 level plus turbocharger deposits.
CEC-L-52-T-97.
OM 602A to MB 228.3 level. CEC-L-51-A-97.
Mack T-8E to CH-4 level. ASTM D 5967.
Mack T-9 to CH-4 level.
Cummins M-11 to CH-4 level.
PDSC oxidation test. CEC-L-85-T-99.
Bearing corrosion Test-HTCBT. ASTM D 596
ACEA E5:
CEC-L-52-T-97.
