"04 Golf TDI - 13,000 km.
Smoking, hard start - new ecu;
Me too!
rear doors out of adjustment - damaged paint in door jambs by w/x
I haven't looked at my door jambs.
stripping;
Common problem
failed wheel bearing right front (squealing);
Common VW problem is premature bearing failure, I expect it to happen eventually
seat heater recall;
VW responded to complaints and did the right thing. I don't see how this qualifies it as a lemon
fuel pump recall;
Again, bad parts replaced under warranty. Luckily mine didn't leak.
AM radio antennae replaced;
NO VW radio picks up AM well, its something I have to put up with on my Moonsoon. I knew this before I bought it by doing research here.
failed cruise control;
I've read here that the switch goes bad and I leave my cruise control on the entire time.
plastic vent parts fell off interior, plastic retainers back-ordered;
Yep, interior is shoddy. I have gear shift knob replaced, center console/armrest replaced and this week I'm having my driver's seat replaced (bad frame that is poking through the fabric)
Alarm system lost its mind and goes of whenever the door is opened;
Typical VW electrical gremlins
And now I have 22,000 km on the car and the catalytic converter has failed (rattles loudly);
You sure it isn't an exhaust hanger?
My passenger seat adjuster broke and they had to remove the seat to replace the cable;
Yikes
The radio antenna has been replaced AGAIN and I still can't listen to the radio without interference/crackling/static - I'm going to get a satellite radio.
Good choice
The clutch is juddering and grabbing,
DMF clutch won't handle abuse
Oh yeah, my best mileage ever was 41 miles per Imperial gallon but still not as good as it should be;
It took me about 20k miles to get EPA fuel economy.
This is the worst VW I have ever had, (my first diesel) and since the late 60s I have had 7.
My alternator failed 24,000 km.
