Old January 30th, 2019, 14:17   #31
imo000
imo000's Avatar
Fuel Economy: Good enough
Originally Posted by Wildbill963258 View Post
...... the tdi is probably the best motor option that vw has available
The 2.0 gas engine is the most reliable engine in my opinion that VW had to offer when the B5.5 was made. Those engines are simple and pretty much bulletproof.
imo000 is offline   Reply With Quote
Old January 30th, 2019, 20:22   #32
Wildbill963258
Originally Posted by oilhammer View Post
Strange how? Ford, Honda, GM, Toyota, and others commonly have 10k mile intervals too.
Most gas cars are 3k miles or 3 months whichever comes first. My truck is a little different because it's a 7.3 so the oil gets heat shear. The interval on my truck is 5k miles or 6 months whichever comes first and that's using heavy duty diesel oil.
Wildbill963258 is offline   Reply With Quote
Old January 30th, 2019, 20:23   #33
Wildbill963258
Plus this is the newest car that I've ever owned in my life so things probably have changed.
Old January 31st, 2019, 05:58   #34
oilhammer's Avatar
Fuel Economy: fantastic
This is not true.
Show me the owner's manual that says this.
I will pick several popular models at random:
2010 Toyota Camry w/ the standard 2AR-FE 2.5L: 10k miles
2010 Honda Accord w/ the standard K24 2.4L: 10k miles
2010 Ford F150 w/ the 4.6L Triton V8: 7500 miles
2010 Chevrolet Malibu w/ the 2.4L Ecotec: 7500 miles
2010 Volkswagen Jetta w/ the standard 2.5L CBTA : 10k miles
2010 Nissan Altima w/ standard QR25DE 2.5L: 7500 miles
.... I can go on... I have the publications right in front of me. All the way back to 1984. You want something older? How about:
1990 Toyota pickup w/ 22RE 2.4L: 7500 miles
1990 Honda Civic w/ the D15B2 1.5L: 7500 miles
1990 Ford Taurus w/ the 3.0L "Vulcan" V6: 7500 miles
1990 Mazda 626 w/ the non-turbo 2.2L: 7500 miles
oooh... let's pick a weird one...:
1990 Daihatsu Charade w/ the standard 1.0L 3 banger: 5k miles
www.cardocautomotive.com
Old January 31st, 2019, 06:21   #35
I guess it's the newest car by a lot. My '92 Camry had a 7,500 mile oil change interval. Hell, I don't recall what the interval was on my '78 Rabbit diesel, but I know it was more than 3,000 miles.
And I just looked it up: Manufacturer's recommended change interval for the 7.3L Powerstroke is 6 months/5,000 miles, except in severe duty conditions, where it's 3 months/3,000 miles. Everyone thinks their vehicle gets severe duty, but few do.
Old January 31st, 2019, 08:40   #36
Sprocket
Sprockette's hubby
Sprocket's Avatar
The 3 months or 3k mile intervals are pushed by quick lube oil change centers, some auto parts stores, and then there are dealerships who also recommend their own "dealer recommended service intervals" instead of going by the manufacturer's recommended service schedules.
2005 B5.5, TD Tuning, R783s, GTB2260VK, 6 speed O1E, BSM 2/09, Pod w/ 40 PSI & EGT Gauge, Thor Skid Plate, Cat FF, Euro switch
1996
B4V, 2.0L w/ BHW pistons, Rosten Rods, Girdle, 11mm, GTB1756vk, RC6, PP764s, .622 5th, Colt Cam II, Ecodes W/leveling motors & Euro switch, fog lights, Koni Yellow, Cat FF, Whitbread 2.5" DP, exhaust, FMIC
Sprocket is offline   Reply With Quote
Old January 31st, 2019, 10:36   #37
imo000
imo000's Avatar
Yup, this is exactly what is happening. They scam customers into wasting their money for something that is not needed. They advertise this BS so many times that people start believing the adds as opposed to what the engine manufacturer says. Seen it many times. The owner's refuse to believe what the owner's manual states and think they are smarter than the people that designed the engine. Every time this comes up during a discussion I asked them "Do you replace your tires when they are 40% worn?". This is when some of them would "see the light" and understand how wrong they were. The rest will not change their mind regardless what I say.
Old January 31st, 2019, 10:47   #38
oilhammer's Avatar
It isn't just the quickie lubers though. I think it is the general public and the prevailing stupidity and wastefulness. Plus, the fact that checking/topping off the oil BETWEEN services seems to be such a difficult thing, I have no idea why.
There are a LOT of people who somehow think it is more convenient to make an appointment, take time out of their day, bring a car in, and pay to have the oil changed than it is to just check the oil and top up if necessary. Something ANY able bodied human can do, no special skills or tools required, can be done anywhere there is light and a level surface.
What I really get a kick out of, is that there are a lot of people who will never, ever check the oil, gladly pay to have it changed thrice as often as necessary, yet cheap out on everything else. Never rotate the tires, and buy the cheapest rubber Chinese garbage they can fine, neglect filters, fluids, etc.... but boy they'll change the dickens out of that oil.
Old January 31st, 2019, 15:04   #39
dogdots
dogdots's Avatar
TDI(s): None
My late '99 Superduty Powerstroke 7.3 got changes every 10k miles and it had over 360k on it when it was totaled (rear ended while parked) last fall. The only parts that truck ever needed beyond normal wear items was a crank position sensor o-ring to fix an oil leak and the oil pressure sensor for the injectors. I did replace the valve cover gaskets (they have the injector and glow plug harnesses integrated) when I replaced all 8 glow plugs and I added cruise control by swapping in a cruise wheel and clock spring.
When I was growing up my dad changed the oil in everything at 2k miles with Castrol GTX. Everyone told him he threw away better oil than they put in their cars
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, both white, 1999 Superduty 7.3 ZF 6 speed, 2007 BMW 328xi, 2003 Mini Cooper, 1977 MB 280SL, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old February 1st, 2019, 06:09   #40
oilhammer's Avatar
Shoot, our old tow company had a fleet of trucks, mostly F-trucks with 7.3L, and they ran 15k mile service intervals, and they were all on the road after 300k+ miles, and had to be put BACK into service after they retired them, because before they could get their name off the side of them and get them to auction, all of their 6.0L replacement trucks blew up. All of them, 100%.
So if to truck use doesn't fall under "severe service" I don't know what does, and all those 7.3L trucks survived just fine. Some of them actually were running (meaning, the engine was never shut off save for a couple times during refueling where the oil was checked) for DAYS on end. The winter weather meant pile ups and crashes constantly, so they were hot seated, meaning when one driver's shift ended, he got out of the truck and the next driver got right in. 24-7.
Those old Fords were indestructible. After the 6.0L debacle, they switched to the Sterling Bullet trucks (cab chassis Ram with a different grill) with Cummins engines, and a few Isuzu NPRs. Not sure if the 6.7L in-house Ford diesel has been able to win back any of those buyers or not. We really do not see any of them in here for service, so I have no idea how well they hold up.
Old February 11th, 2019, 00:57   #41
kaneelschep
Did you get the overboost issue fixed?
Check my posts about it.
I have been fighting an overboost for quite a while now.
Meanwhile driving 100km to a new workplace and back every day, having a new baby, moving to another country with a 2ton trailer and buying and fixing up a new house.
things became better, worse. Changed during, other things broke..
They are old cars.
But in the end its not a very big deal.
And the only thing that can happen, is that you have a slow car.
First! check that maf. Swaptest it with one that works from a junk car or friend or random person at the gasstation.
If thats ok. then go to the vacuum system.
Google a vacuum diagram for your engine. Print it and keep it at the car!
Then go buy 5 meter of 3mm, and 5 meter of 5mm tube. Silicone or rubber benzine hose. Something strong and durable. Dont know those sizes feet or thumbs.
Cut to size and replace every vacuum line one by one. Its a very easy job, and very rewarding.
Now blow on those lines one by one to see if there is an obvious culprit.
If it lets your air through, its leaking. also check the couplings! Check the hose from the vacuum pump to brake booster.
For instance where the brakebooster goes through the rubber at firewall, my rubber leaked. Later my heater valve leaked. new ones were cheap and relatively easy to find.
for the big hoses on the ic and pipes. Get some decent hoseclamps. Mine never came off.
They are cheap, very easy to reach and swap..
Now the last thing is probably the vanes being stuck by coal residue.
Push the rod going into the turbo. If it doesnt go smooth and easy. They are stuck and will throw a limp mode.
I am going to see if the mr muscle trick will solve it.
I spent a day reading and looking through results of people trying it. And for a lot of people it solved their sticky turbo vanes problem without any issues.
kaneelschep is offline   Reply With Quote
1997 Passat TDI Station wagon (B4V) Mcgink TDI Cars for Sale/Wanted 44 February 26th, 2014 18:01
1996 Passat Station Wagon TDI!!!!! shweeshy TDI Cars for Sale/Wanted 14 August 6th, 2012 01:24
1997 PASSAT TDI STATION WAGON - for sale robibadi TDI Cars for Sale/Wanted 1 April 18th, 2005 04:55
For sale: 1996 Passat TDI STATION WAGON Bob L Private TDI Items for Sale/Wanted 18 December 1st, 2002 20:05
WANTED: A 96/97 Passat tdi Station Wagon... goldandblack VW MKIV-A4 TDIs (VE and PD) 5 November 21st, 2001 06:53
Page generated in 0.16180 seconds with 13 queries
[Output: 115.03 Kb. compressed to 98.70 Kb. by saving 16.33 Kb. (14.20%)]
