Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Non VW Group Diesels
Non VW Group Diesels This section is for discusion of Non VWGroup Diesels.
Old January 16th, 2019, 17:33   #871
Lat
Lat's Avatar
How long did the harmonic balancer last? I'm thinking of replacing mine as PM at 60K miles.
Mine croaked at 108k km = 67k mi.
Lat is offline   Reply With Quote
Old January 16th, 2019, 18:29   #872
Thanks for the info. Maybe I will replace it at 60K miles.
Old January 16th, 2019, 20:38   #873
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
It's pretty unscientific, but you can do a visual on it to see if the rubber mass between the inner and outer rings looks bad. If it's got any pitting or cracking to it, get it out of there. If the rubber looks nice and smooth and black, maybe you can go awhile. I'm guessing a car kept in a climate controlled garage would get more miles out of the HB than one sitting outside in a place with lots of freeze/thaw cycles.
2011 BMW 335d - JR 2.8
Blue_Hen_TDI is offline   Reply With Quote
Old January 16th, 2019, 20:48   #874
dogdots
dogdots's Avatar
TDI(s): None
Mines never been parked inside and I'll hit 119k miles tomorrow on my way home to KC from Minneapolis, still on the original balancer. Maybe luck of the draw? I'll be inspecting mine soon and had planned to order the fluidampr now that they are back in stock. If mine looks ok I'll hold off getting it until I am in Atlanta in March and just pick it up in person.
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, both white, 1999 Superduty 7.3 ZF 6 speed, 2007 BMW 328xi, 2003 Mini Cooper, 1977 MB 280SL, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old January 23rd, 2019, 10:49   #875
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Smile
Originally Posted by nicklockard View Post
Most people on the e90 forum report them going out around 120,000 miles. Mine gave out at 139,000.
Peter, when you fitted the Kosei's, did you ever find BMW center caps to fit them?
I'm only at 207k miles on my 2012 X5 35d (M57 engine) and it still has its original HB.
Why DIESEL is better: (Courtesy TDIclub forum member wxman)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
n1das is offline   Reply With Quote
Old February 7th, 2019, 08:33   #876
dogdots
dogdots's Avatar
TDI(s): None
I was in Minneapolis this week, lots of snow the past couple of days. I left at midnight headed for KC to try to beat the worst of the storm driving my 335d. When I left Minneapolis there was enough freezing drizzle to keep the top third of my windshield icy until the drizzle changed to heavy snow just after the Iowa border. Drove through constant snow until the Missouri border, then it cleared up shortly after. Car did fantastic on the ice and snow with the all seasons, I haven't even put on my Blizzaks for the season yet. Probably won't at this point. I couldn't figure out why my headlights weren't projecting well until I stopped for fuel and knocked 1/4" of ice off each one
The good news is I got 44.6mpg calculated at fill up on the trip home, the bad news is it took me 3 hours longer to get home because of the icy and snowy conditions. 436 miles door to door, 9 hour drive time.
Old February 7th, 2019, 17:29   #877
DubFamily
Fuel Economy: It's still a diesel!
-Jason G
Originally Posted by kjclow View Post
Dub said it better.
2014 BMW 328d xDrive
Member SSBMWO
DubFamily is offline   Reply With Quote
Old February 7th, 2019, 21:08   #878
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: No data yet.
Dubfamily,
Not sure it it's just me, but all I see is a massive post and two huge minus signs--no images load.
335d update: I just got air shocks installed in the rear for towing. This gains 23.6 mm of additional clearance, or putting my rear close to stock ride height (PO had installed coilovers, which ride great, but are quite low). So now I kind of have a good hybrid suspension setup: progressive rate coilover struts in front, progressive springs and air shocks in rear. I had an automatic compressor/controller installed with it. It all adjusts easily with a small remote that clips to my visor. The controller/compressor is wired to an ignition-on fuse. Next up is mounting the Execuhitch and buy a spare tire/wheel.
nicklockard is offline   Reply With Quote
Old February 8th, 2019, 11:42   #879
jck66
jck66's Avatar
@nicklockard, please share your experience with the execuhitch installation and use? I'm considering one for my F10 535d and would be interested in information other than marketing materials. TIA!
jck66 is offline   Reply With Quote
Old February 8th, 2019, 13:58   #880
Blue_Hen_TDI
I had my tired original 335d sport suspension replaced with the Bilstein B12 Pro-kit (B8's w/Eibach springs), new shock/strut mounts and spring pads, as well as complete M3 control arms and new tie rods. After waiting two weeks for a bit of shake out and settling, I'm currently at the shop for 4-wheel alignment. The car already felt great. Should be even better with alignment and a tad more camber up front.
Old February 10th, 2019, 15:38   #881
DubFamily
Dubfamily,
Fixed it
-Jason G
Dub said it better.
Member SSBMWO
Old February 10th, 2019, 15:43   #882
Blue_Hen_TDI
Originally Posted by DubFamily View Post
As the old saying goes, finally broken in!
Old February 17th, 2019, 08:40   #883
Twinkieflyer
Fuel Economy: 47avg
Well I did it. Bought a 2016 535d xdrive. CPO but can buy up an extra year for 3000.
Car has warranty otherwise thru 8-2021.
The big question, with 30,000 miles on it and doubtful I will drive it more than 15k a year, should I buy the extra year or not. Since I am planning to keep it quite a while, I have started thinking about saving the money for later big $ repairs.
I still plan to drive the Jetta about 1/2 the time. I am going to miss the 5spd.
Need to go pick it up and drive back to VA from Detroit.
Thanks for any advice,
2002 Jetta ALH
2006 Silverado LBZ Duramax
2016 GL350 (wife's diesel)
Kubota 3540, Deere 5085M
Twin Comanche, Cardinal RG
Twinkieflyer is offline   Reply With Quote
Old February 17th, 2019, 10:02   #884
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
Thumbs up
Congrats!! I'm still really enjoying my 2014- every time I drive it.
-tom
autos: 15 Volvo V60, 14 BMW 535d xDrive
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old February 17th, 2019, 10:25   #885
nicklockard
Torque Dorque
$3000 for one year of CPO is absurdly over priced. They'd probably just deny anything important anyway. Around 160k miles, the complete emissions system will go to junk. You'll need the money to resolve it. About $13,000 for OEM or $4000 for 'ABC delete'.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
TDIClub Secret Society of Benz Owners (SSBO) cevans Non VW Group Diesels 622 September 4th, 2018 17:41
BMW 335d owners Capt. Common Rail Non VW Group Diesels 38 January 8th, 2017 20:59
--::Polo Cult Society::-- Mosdef Other TDI/Diesel Picture Gallery 0 November 14th, 2002 12:12
Any BMW owners around here? D-Dawg Non VW Group Diesels 8 January 20th, 2001 10:13
Any BMW 525tds owners out there? dave525tds Non VW Group Diesels 6 April 4th, 2000 03:40
Page generated in 0.16719 seconds with 13 queries
[Output: 141.11 Kb. compressed to 118.70 Kb. by saving 22.41 Kb. (15.88%)]
