LiquidBlackDZL
When installing new nozzles onto the injectors, how important is it to pop and pressure test them? Other than being able to verify that the nozzles are functioning, what other benefits are there? Also, if I were to have the nozzles pop and pressure tested, (specifically PP502's on the ALH injectors), what is the recommended pressure?
I talked to a Bosch/diesel service center that said they could install the nozzles and pop test them, as well as set the pressure to whatever the manufacturer recommends, or based on what kind of performance I was looking at getting from them. I didn't know what to tell the guy. He's charging $40 per injector. Would it be worth it?
