two passat man
Misfire
2013 Passat TDI SEL w/DSG 230,000 miles. I started getting a chatter in 3rd gear under acceleration. If I put it in manual mode and down shift it would go away. It has now started doing it though all the gears. Hard acceleration helps it go away a little. Dealer has done all my service on time. No tune yet, planning on Malone stage 2 with DSG tune in November. I have had flywheel replaced around 160,000.
Update:Faults Found:
8842 - Torque Difference Cylinder 1
P1004 00 [175] - Limit Value Exceeded
MIL ON - Confirmed - Tested Since Memory Clear
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [175] -
10591 - Cylinder 1
P0301 00 [175] - Misfire Detected
P0300 00 [175] -
10591 - Cylinder 1
