Old October 4th, 2019, 15:45   #481
Zygote Bros
TDI(s): 2014 JSW TDI
Originally Posted by Drclaw View Post
Your using Tiguan rear springs correct? How do you think the Tiguan konis would pair with the jsw towing springs? The tow springs are even taller than the Tiguan springs, correct?
Where did you source your sway bar?
Yes, see posts #455 for the spring list and #457 for which Tiguan rear springs I bought (AG). There are A LOT of different Tiguan rear springs. According to the specs from there, the thickness of the metal is the same diameter as the towing springs, but the overall length is 21mm shorter (about 3/4 inch unloaded, about 1/2 inch loaded). I don't remember if that makes the spring slightly stiffer or softer than the towing springs (someone can chime in here if they want). From what I read, the towing springs are about 190 lbs. and the stock springs are about 145. I don't know the strength of the springs I have.
Regardless, I think the Tiguan Konis would be good with the towing springs if those springs are no stiffer than the Tiguan springs I have. If you want to experiment a bit, I'd find someone selling some lightly used Tiguan OEM rear struts for cheap and try those...might be worthwhile. With the extra height of the towing springs, I think you want a little compliance in the rear end, otherwise IMHO the car starts to feel a little tipsy and has a little more understeer.
How do you think your car feels right now? Can you can push the rear end down easily (I could with the Jetta Koni SA in the rear)? Does it feel wallowy in the rear on the freeway?
Zygote Bros is offline   Reply With Quote
Old October 10th, 2019, 14:10   #482
swampfox69
TDI(s): Sportwagen
Sorry if this has been covered. I extensively searched this thread and the forum in general without a clear answer. Is there a maximum tire diameter for a stock suspension mk6 Sportwagen? I am thinking about 205/65r16 tires. Will I run into rubbing issues without lifting?
swampfox69 is offline   Reply With Quote
Old October 10th, 2019, 14:42   #483
wally_world_jb
I was running 215 55 16 pre-loft and did noy rub -- when unloaded. But a JSW with 4 people and luggage gets a saggy rear and rubs the wheelwell with every bump in the road at that size. Compare your option to that through www.tiresize.com
Sent from my LM-Q610(FGN) using Tapatalk
wally_world_jb is offline   Reply With Quote
Old October 10th, 2019, 14:46   #484
JediJoker
JediJoker's Avatar
TDI(s): 2011 JSW 6MT
My dad ran that size for a hot minute on his JSW and reported rubbing, sometimes.
- JediJoker
"Dieselgate" / 2011 VW Jetta SportWagen TDI 6-speed
JediJoker is online now   Reply With Quote
Old October 10th, 2019, 16:18   #485
wally_world_jb
Yup. So glad I lifted...no more droopy jsw butt!
Old October 12th, 2019, 20:15   #486
Wilkins
Fuel Economy: 4.6/5.6 - 5.3/6.7
I’m running 215 55 17 which are supposed to have a diameter of 668 mm. I wouldn’t go larger, clearance on the front is pretty tight. 215 65 16 is shown as 686 mm, nearly an inch larger diameter.
2005 Jetta Wagon: Evo skid plate, Kerma Tune, Moog VR6 front springs, Koni Reds, Jeff's HID's, Upgraded door switches!. MKVI: Containflo+Pureflo, Rear Tiggy springs and B6 Billies, Xenon w LED, AFS, 087T BCM
Wilkins is offline   Reply With Quote
Lift for TDI Sportwagen (for oversize tires) BioDieselLover VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 January 25th, 2012 08:37
Resetting for oversize tires. Lightflyer1 OBD Scanners 6 March 24th, 2011 23:36
Do oversize tires cause problems with ABS or ESP? wesmontage VW MKIV-A4 TDIs (VE and PD) 7 August 27th, 2010 21:21
Tires for '09 Sportwagen TDI tdiatlast VW MKV-A5 Golf/Jettas 7 January 27th, 2009 05:55
Any Advantages of Oversize Tires? jaberoo Upgrades (non TDI Engine related) 8 February 19th, 2007 19:39
Page generated in 0.14367 seconds with 11 queries
[Output: 79.30 Kb. compressed to 69.93 Kb. by saving 9.38 Kb. (11.82%)]
