I have a 2005 BEW Jetta that has issues starting. The car has 185,000 miles. I have recently replaced:
I have checked glow plugs and swapped working glow plug relay from dad's car--no difference. Since owning I have had slightly long cranking cycles every time I start the car. Cranking is normal pace but it takes longer than normal to start. So much so that I have already replaced the starter once. Cranking time has lengthened here recently and now it is not starting at all sometimes. Much more recently (started to happen more frequently immediately after replacing tandem pump but I'm unsure if related) it cranks a few times then stops and makes a weird sound. I took a video and will link in the forum bellow of exactly the sound it makes when cranking. If you watch the video you'll see that the last time I attempt to start I give it some gas and it reluctantly starts. I underline the last part because that is my main concern with starting cycle at the moment. I realize that many watching the video will point out that I have a starter issue. The starter is probably wearing out since I have been cranking hard for about 3 months now. I get a check engine light every time I get a no start. It is always a G40 camshaft sensor no signal or intermittent signal.
Dad suspects a fuel issue but is tired of working on the car. I need help!!
https://youtu.be/YWjdab-YYRY
- Timing belt (timing now at +0.05)
- Clutch
- Tandem pump
- Lift pump
- Camshaft sensor (used but working part)
