Mclovin69
My 2002 jetta tdi started acting up a while ago. It was going into limp mode. and when looking on this site I found it could be the MAF. So I changed it and it seemed to make a difference. I parked it for winter and just pulled it out for another season and found that it is having that problem once again. I will hit the highway and start accelerating and if I'm lucky, it will start to accelerate quicker so I put the pedal to the floor. It smokes black through all the gears up to highway speed not alot but enough to notice. Or if I'm not so lucky, the car will start to accelerate and start to actually speed up but then give a puff of black smoke and go onto limp mode. It is obvious when it accelerates better. It's almost like it takes till 60kmh to spool up the turbo and actually have power... or go into limp mode. It's probably not what's happening but you can definitely feel the second it goes into limp mode. The engine light is on. I haven't checked it in a while but it's been on before for low boost (and MAF fault before I fixed issue) anyone know what might be happening?
Sent from my SM-G950W using Tapatalk
