ALH lift pump install how to?
reddtekk
Waterbury, CT
1996 Passat TDI
Please excuse the noobish question, but what's the reason for retrofitting a lift pump to an ALH? Is it to support engine mods?
I know this is an old post don't beat me up...
Just a couple other good reasons for adding a lift pump would be to make fuel system priming a lot easier after running out of fuel or changing a fuel filter, and it takes load off the transfer pump in the IP. I am strongly considering installing one for those reasons.
kiwibru
Distant island in WA. state
Golf 2-door, 2k Silver. Red RTDI now gone but not forgotten!
I have always thought of this as a push / pull relationship in the ALH. Nothing like making the movement of fuel an easy bit of work with the in tank pump pushing and the lift in the IP pulling at the same time. Can't believe they did not implement this earlier as an OEM setup in the ALH.
Vince Waldon
Edmonton AB Canada
"Parts left out cost nothing, and cause no service problems".
Charles Kettering, Head of Research at GM 1920-1947, inventor of the starter motor, leaded gasoline, and Freon-based air conditioning. :)
Votblindub
NY
MK4 Jetta Wagon
It also helps people with extensively modified engines to keep fueling their motor at higher RPM ranges. That's one of the reasons my wagon has a lift pump.
GEFP
Southern Alberta Canada
2- 2001 Jettas, 2 - 2002 Jettas (1 for parts) 2003 1.8t Jetta (parts) 2014 Jetta
So now I'm curious. At what horse power point is a lift pump a good idea? At what point is it necessary to add a lift pump to prevent hp loss at higher rpms?
Votblindub
NY
MK4 Jetta Wagon
Personally, I wouldn't say that there's a figure, but it's more about the engine build. Mine is built to spin up much more than a stock ALH and is capable of higher RPMs. It'd be required to run more fuel at higher RPM to keep producing power past 5000 RPM. If you build it extensively with a built head, an aftermarket cam, valves, valve springs and all that good stuff, then I would say it's helpful. But, you can also do it for easier startups, easier priming of those pesky fuel filters and such.
jhax
Golden, CO
96 Passat B4V, ALH engine out of a 2002 Jetta, some IE Rods and ASV Pistons. Nothing drivable yet though
The picture of the relay has a description next to it... "Fuel cut-off on pump(signal wire)" which is the wire on the top of the pump head just before where the metal injector lines come out.
Liftedw@gon
Ontario Canada
Alh
Do you have a picture of yours ?
this is the first time and I don’t wanna **** it up already got stranded 3 hours from home waiting on side of road for 2 hours
MAXRPM
US
00 Jetta and 99.5 Golf, 2015 Passat TDI,BMW 2
Follow the schematic it is easy to wire it up
derek5120
Arthur Ont.
2003 jetta GLS
Does everyone do the in tank pd pump or are there guys running inline fuel pumps? I was going to install a inline pump from a 6.5L gmc diesel under the hood (push/pull pump rated for 32gph) they are cheap and plentiful. I guess they probably don't flow as much as the vein style pump, but when you compare to the factory no lift pump it should still be a improvement.
Liftedw@gon
Ontario Canada
Alh
I did the intank lift pump only because I did a alh swap to a clean bew wagon
Rrusse11
PA Deutsch Country
2002 Golf, 5spd; 05 Jeep CRD
"Does everyone do the in tank pd pump or are there guys running inline fuel pumps? I was going to install a inline pump from a 6.5L gmc diesel under the hood (push/pull pump rated for 32gph) they are cheap and plentiful. I guess they probably don't flow as much as the vein style pump, but when you compare to the factory no lift pump it should still be a improvement." dereks5120
Similar situation that I have installed in my Jeep "05 Liberty CRD. The PO had simply installed a $25 inline pump,
the VM motor as it ages has a tendency to lose prime. He did point it out when we went over the car. It did die, and yes, the car stopped unexpectedly a couple of times. The Jeep has a hand primable fuel filter, so it didn't take much to get it going again. Replaced the pump, judging from the POs receipts, about 5yrs old. No more problems.
The "proper fix", at least as espoused on the Jeep forums, is an intank lift pump. After dropping the tank, and going through fairly extensive procedures, a solid 4-5hr job, and >$300 with the right harness. Took me mebbe half an hour
on the Rhino ramps, one side, a couple of crimps and plugging some hoses back on, <$30, to put a new inline pump in. And I'm a slooow mechanic.
With the amount of fuel needed to assist the fuel pump, even at high power and revs, I suspect it won't make a bit of difference to the motor if you go a small inline pump.
Laszlo
Hungary
SEAT Ibiza 2001 ASV
I share what I haven't found here, to help:
The professional tuners says that a lift pump could help but not necessary. There are 300+HP cars without liftpump, you need a good VE Pump and fuel system.
-If the lift pump is underscaled, it becomes a rough resistance in the system at high revs. The VE has a very good pump, it can easily achieve 0.6-0.7bar of vacuum, then it sucks air into the system everywhere. The result is sky-high EGT and melted turbo about <10sec because the preload adjuster piston cannot work in a system which contains air. (if you don't have an EGT gauge you realize only the lack of boost, because the doses don't decrease despite the vacuum)
-don't use high pressure pump (e.g. gasoline pumps) because the positive pressure on inlet side of VE pump is also a resistance for the preload adjuster (or timing) piston.
To scale the fuel system (estimation):
ca. 0.5 l/min needed in every 100 HP and 0,5l/min for backflow (independent to HP)
With lift pump the pressure must be +0.3 to 0.8bar at idle and +0.1bar to 0.2bar at max load.
(without lift pump you need proper filters and larger pipes to keep the vacuum under 0.3bar)
-the story have to be ended with controlling what you have done...
PakProtector
AnnArbor, MI
Mk.4's and the Cummins
And Laszlo, one does not want to overpressurize the IP as the front seal can get driven out. At least the fuel will just leak out instead of commencing a dilution of the crank case oil that the gear-driven Cummins-es suffer. Going to have to do this on my ALH; if only to make fuel filter changes simpler... :)
The Carter 4601 is a diesel-rated pump that puts out about 8 psi. Loud, but bomb-proof.
cheers,
Douglas
Judson
Cheyenne, WY
2001 Jetta
If you have (had) an auto like me the small relay box next to the vacuum booster is missing. But you can get that plus some used relays, wiring, and relay plugs off of ebay and retrofit…. I have my lift pump and HID ballast relays in there.
J_dude
SK Canada
2003 1.9l “Jedi”
cheers,
Douglas
Are you installing this Carter pump on your TDI?
