Matthorton
My dash flashed at me today saying something like "low oil pressure - stop engine".
The car is a European 2010 B6 Passat with engine code CBAB (16valve 140hp)
I put the car in 2nd gear drove about 50meters back to my driveway with the engine at idle and then I turned off the ignition. I went back a bit later to start the car to see if the fault had gone - I revved in neutral to 2k rpm and the light came on again. At this point, I lifted my foot off the throttle and the engine cut out by itself. I started it again to see if it would idle, and it did idle but it felt like it wanted to cut out so I turned off the ignition. This is how I've left it.
As a side note, the turbo actuator has been blowing its 10 amp fuse every couple of days for the last couple of months and I have been replacing it every time. Except, about a week ago the fuse stopped blowing but the turbo whistle became louder... I don't know if any of this is related to my fuel pressure though!?
I'm on a tight budget and I'm not afraid of getting my hands a little bit dirty. What should I look at doing first to get it fixed?
