shoebear
- Joined
- Aug 1, 2002
- Location
- Colorado Springs, CO
- TDI
- 1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
I'm re-mounting my 05 NB transmission after a clutch swap, and I need to bolt the mounting bracket/console/side mount to the trans case. This is done with 3 M10x80 bolts with 16mm hex heads numbered 1-3 below:
I looked several times in my New Beetle Bentley and couldn't find torque values for these, or instructions whether to replace every time or not. Then I looked online, and I found two answers: 37 lb-ft +90º and 30 lb-ft +90º. The latter value comes from runonbeer, whose opinion I respect. I'm guessing 37 is the spec, but he felt that was a bit too tight?
Second question: There are two part numbers for the bolts, one with blue threadlocker pre-applied and one without. Long story, but I have both on hand. Which should I use?
Here's a thought: Maybe 37 lb-ft +90º is for N10406204 because the thread locker provides extra resistance, and 30 lb-ft +90º is for N10406203 (without the thread locker)?
Thanks for your help and insight!
- 37 lb-ft +90º Bottom of https://www.myturbodiesel.com/d2/1000q/a4/transmissionremovalbak.htm
- 50Nm (37 lb-ft) +90º jcrews #5 https://forums.tdiclub.com/showthread.php?t=294996
- 30 lb-ft +90º (for 02M) runonbeer #93 https://forums.tdiclub.com/showthread.php?t=76249&page=7
- 30 lb-ft +90º runonbeer #131 https://forums.tdiclub.com/showthread.php?t=76249&page=9
- N10406204 10x80 hex head bolt with shoulder, self-locking
- N10406203 10x80 hex head bolt with shoulder (not self-locking)
