pkhoury
That guy with the goats
I
Actually, my Kubota also runs at 1800. I'm not that wild about 3600 RPM generators; way too noisy for my taste.
I'd be more than happy with 40kw, and @burpod could write the tune for it lol.Alright...on the genset. Need an 1800 rpm generator for one( no sense spinning it at 3600 ). Speed at varying power needs to be maintaiined carefully( this is what sets the line frequency of 60 Hz ). This bit is important. Not having it over freq, and over voltage( likely at the same time ) are not in the ALH's ECU behaviour. It could be a solid governer could be coded in...
However, a smaller engine would likely be better as one can run closer to the max efficiency island...an ALH will likely be quite happy running to 40 kW continuous...
Douglas
