About the Passat...
Is it me or is that dyno plot asking for a boost valve?
Joe, do you have any info on other stuff going on after the module goes in:
boost changes
spikes
surges
egt
Anything like that.
Also, how has the typical lag of the Passat been affected from the module?
They have done EGT testing in Germany where they drive the cars with sustained 200 kmh for long periods of time and the EGT always remains within 5% of stock. The engineers are proud to report that they have never killed an engine or turbo.
-There are no surges on the road, the power comes on smooth and linear throughout the range.
- The boost pressure will come up normally but is not controlled to increase boost by our system.
- We have ordered boostvalves from
Boostvalve to work in conjunction with our three wire PD module.
- the only lag we have on the TIP Passat is when you floor it and the tires lose traction for the first 30 feet, that lag kinda sucks because if this car had great traction I am sure we could run this heavy Passat under a 16 second quarter mile
[image]
[/image]
