Grabbing pics here in a moment. Will likely post them and then get on my comp to resize them.
Its in the lower center grill. The metal bar, behind the bumper that the styrophone sits infront of.
Hard access, and not a lot of room for error; but you drill a hole and use nuts and bolts.
Depending on your light, you may only need afew washers to align it in the grill, or a whole bracket like mine(because the light mounts were shallow)
Its ran through a relay,directly to the battery; switch is located inside on the dash, next to the emergency flashers.
First pic is the old setup, two 9.5" lights, so i could point them toward to outside of the roadway. Then i went to the 20,
https://www.amazon.com/dp/B077837LX8?ref=ppx_pop_mob_ap_share
Sent from my VS987 using Tapatalk
The read squiggly is the general shape of my home made bracket; the yellow arrow points to it... Its 1" or 1.5" wide steel.
