Old December 15th, 2011, 17:30   #31
silverbox
silverbox's Avatar
Fuel Economy: 55mpg highway@100kph
Think I found a spec sheet:
TYPICAL PHYSICAL CHARACTERISTICS
Rotella T6
SAE Viscosity Grade Rotella T6
5W-40
Kinematic Viscosity (ASTM D 445)
@ 40C mm2/s
100C mm2/s
87
14.2
Dynamic Viscosity (ASTM D 5293)
@ -30 C mPa s 6000
Total Base Number mg KOH/g
(ASTM D 2896) 10.6
Sulphated Ash % (ASTM D 874) 1.0
Density @ 15 C kg/l
(ASTM D 4052) 0.858
Flash Point (COC) C (ASTM D 92) 224
Pour Point C (ASTM D 97) -45
KERMA tune, PDliftpump,11mmIP Race 520's. PD150 Intake manifold&TIP, 1722 turbo, Upgraded IC pipes and Eurojet SMIC.Stealth racepipe. 2.5DP+catback areoturbo2525 muffler. Peloquin LSD.
Koni FSD's +VR6 springs, 23mmRSB, 16x7w/Conti DWS. GLI Recaros, Wingnut short shifter, Ecodes w/relays+60/100h4's.
Cat2 Fuel filter DG/Amsoil Bypass filter
silverbox is offline   Reply With Quote
Old December 15th, 2011, 17:32   #32
silverbox
silverbox's Avatar
found it here:
http://www-static.shell.com/static/c...cants/1-52.pdf
Old December 15th, 2011, 17:37   #33
silverbox
silverbox's Avatar
Bob with the
@ -30 C mPa s 6000,
Is this a light weight 5w?
Old December 15th, 2011, 18:15   #34
jettawreck
jettawreck's Avatar
Originally Posted by silverbox View Post
The Rotella t5 0w40 sold in Canada is synthetic.
Quote from jettawreck:
"When I go up to Ontario ice fishing they have a 0-40 Rotella, but I see it's not full synthetic."
T5 0w-40 is a synthetic BLEND, not full synthetic like T6 per Shell's website and from info I recall from reading the bottle(s).
2004 Cadillac SLS (wife's)
jettawreck is online now   Reply With Quote
Old December 15th, 2011, 18:43   #35
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Rotella T6
5W-40
@ 40C mm2/s
100C mm2/s
87
14.2
@ -30 C mPa s 6000
(ASTM D 2896) 10.6
Density @ 15 C kg/l
(ASTM D 4052) 0.858
That looks correct. The US version of the datasheet doesn't show much info
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old December 15th, 2011, 19:01   #36
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Bob with the
@ -30 C mPa s 6000,
Assuming this info is correct: http://widman.biz/English/Tables/J300.html
T6 exceeds the 5w minimum rating of 6600 @ -30C by a fair margin.
The great unknown with all this is what happens at temps warmer than this, but colder than 40C. This can be extrapolated to a certain point based on VII, 40C and 100C viscos.
TDT's VI of 153 vs T6's of 170 is significant.
Old December 15th, 2011, 19:10   #37
silverbox
silverbox's Avatar
Bob the castrol edge 505.01 is specced at Viscosity, CCS -30C ASTM D5293 mPa.s (cP) 5550, how close is that to 0w?
Old December 15th, 2011, 19:11   #38
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
While it has the SB moniker, Rotella T SB 0w40 is 100% synthetic. Why Shell did that... who knows.
"Rotella T SB 100% Synthetic 0W-40"
http://www-static.shell.com/static/c...cants/1-15.pdf
In the ALH I would run Mobil 1 0w40, Rotella T SB 0w40 or D1 ESP 0w40 without worries. (or any of other Euro 0w40s)
Old December 15th, 2011, 19:13   #39
silverbox
silverbox's Avatar
Also, what does the higher flash point on the T6 mean?
CE 505.01 FP 210c, VS T6 FP 224c
Old December 15th, 2011, 19:17   #40
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Unknown exactly since 0w and 5w are measured at different temps.
Old December 15th, 2011, 19:20   #41
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
I can't give you a good explanation (I don't know exactly), but this might help.
http://www.blackstone-labs.com/what-...lash-point.php
Old December 16th, 2011, 02:49   #42
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Wow, this many views and posts with no one complaining it's a Group III+ oil
Old December 16th, 2011, 03:09   #43
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
Originally Posted by Bob_Fout View Post
Well well well, after flirting with some of the more exotic oils over the past few years (Mobil 1 0w40, Mobil 1 ESP 5w30, Redline 0w40) next oil change is going to be Shell Rotella T 5w40.
http://www.shell.com/home/content/rotella/products/t6/
http://www-static.shell.com/static/c...rotella_t6.pdf
Been there from the beginning Bob . The trick is to find it in single quarts, since they refuse to sell a 5 quart bottle. Walmart and Meijer don't seem to carry the single quart and when they do it is close to seven bucks.
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Old December 16th, 2011, 03:13   #44
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Fancy there dog
Have you tried FLAPS, truck stops or 'farm-type' (rural king, fleet farm, farm and fleet etc) stores?
Old December 16th, 2011, 13:56   #45
shadowguy
shadowguy's Avatar
Fuel Economy: low 40s
I have seen single quarts of T6 in one Wal-Mart here (Mountain View), but another only had 4L jugs (Milpitas). The cons of owning a diesel I guess. Oh and neither one carries a battery for my A3
Kids, you tried your best, and you failed miserably. The lesson is, never try.
shadowguy is offline   Reply With Quote
Mobil 1 VS. Rotella T6 Poolboy1191 Fuels & Lubricants 40 November 24th, 2011 11:49
Shell Rotella T6 5w40 VOA Bob_Fout Fuels & Lubricants 2 July 30th, 2011 02:13
Rotella T 5w40 now Rotella T6??? Joester Fuels & Lubricants 13 February 5th, 2010 16:20
Rotella T6 & Rotella T SB? kwalsh24 Fuels & Lubricants 8 January 28th, 2010 16:38
Rotella T6 werewolf TDI 101 6 January 20th, 2010 15:42
Page generated in 0.15040 seconds with 11 queries
[Output: 145.47 Kb. compressed to 122.87 Kb. by saving 22.60 Kb. (15.53%)]
