wjdell
It does look pretty good cept maybe the Fe
You need a soot test.
Unfortunately I think this is a typical result from Amsoil AFL -- it's just not as good as some other 505.01-rated oils, and not as good as the API-rated Amsoil DEO.mkinner said:Here is my first analysis on my 05 jetta PD w/ 49500 miles on engine, 9200 on the Amsoil European car formula:
(snip)
Iron: 74
This was the only oil change that i ran Amsoil European in it and the test came back better than i thought!
WJ, your driving conditions are not real world for most people. Yours is the only good AFL UOA that we have seen.wjdell said:AFL was the same as Motul in my car - I think its fuel and the driver.
WJ, that is an understatement. You and SUNRG probably could run butter in your crankcase and have a UOA.wjdell said:My AFL is good because my motor was in good condition and clean when it was used.
?????wjdell said:There are not that many AFL UOA's and the ones who did poorly did poorly with any 505.01 they used.
try to look at the following data objectively: 2 UOAs, same engine, same fuel sources, identical soot levels. we would expect Fe wear to be higher in the first UOA since the engine was still wearing in (oil in service from 30-41k ODO) but Fe wear was 139% higher for the oil in service from 60-70k ODO. could this Fe spike be unrelated to the oil - absolutely!the ELF 5w40 was in service from 30-41k ODO. the UOA is on this report - 76ppm Fe @ 11336 miles for an Fe wear rate of 6.7. the engine was still young then so those numbers are OK especially considering the 2.2% soot!
the next UOA was AFL which was in service from ~51-60k ODO. 99ppm Fe @ 9692 miles for an Fe wear rate of 10.2. soot was still elevated but slightly lower at 1.7%. 10.2 is a relatively high Fe wear rate for oil in service for less than 10k from 51-60k ODO.
this UOA is AFL in service from 60-70k ODO. 163ppm Fe @ 10156 miles for an Fe wear rate of 16.0. soot is back up to 2.2%. your engine is Fe wear rate is now 139% higher than during its 30-41k OCI and the soot concentration is the same.
Yeah, that's what I'm thinking too. The airbox was full of sand too (hence the silicon).wjdell said:Looka the sodium but no patassium - so it probably is not a coolant leak as they state
He had a intake leak and followed people spraying salt off their tires.
Element Conc(ppm)
Al 0
Cr 0
Fe 0
Cu 0
Pb 0
Sn 0
Mo 80
Ni 0
Mn 0
Ag 0
Ti 0
K 0
B 214
Si 3
Na 4
Ca 1062
Mg 7
P 764
Zn 908
Ba 0
SUS @ 210F 65.1
cSt @ 100C 11.63
Flashpt F 485
Insol % 0
TBN 5.1
Very high flashpoint, viscosity toward the high end for a 30-weight oil. Yes, low starting TBN but DB says this isn't important. We'll find out whether that is true.rhi said:VOA from Blackstone Labs.
(snip)
Mo 80
B 214
Ca 1062
Mg 7
P 764
Zn 908
SUS @ 210F 65.1
cSt @ 100C 11.63
Flashpt F 485
Insol % 0
TBN 5.1
I'm planning to run this for the next change on my 2006 Golf PD. The starting TBN is a little low (consequence of low SAPS, I suppose), so I'll have to keep an eye on that if the next OCI involves a lot of short trips.
UOA2: Elf Excellium 0W30 @99,600 mi; UOA1: Castrol Syntec 5W40 @89,400 mi
Element UOA2 UOA1
Fe 143 105
Cr 3 6
Pb 1 1
Cu 16 13
Sn 0 0
Al 6 15
Ni 0 4
Ag 0 0
Si 6 11
B 83 53
Na 0 0
Mg 108 214
Ca 2627 2366
Ba 0 0
P 1200 1009
Zn 1457 1161
Mo 4 30
Ti 0 0
V 0 0
K 0 0
Fuel (% Vol): <1 <1
Viscosity @100C: 12.04 10.20
Water: 0 0
Soot/Solids (% Wt): 0.6 1.0
Coolant: No No
TBN: 4.71 3.70
Speaking of the cam, here's a photo taken when I swapped the timing belt shortly after buying the car in Jan. 2006.wjdell said:looks like you went from the frying pan into the fire - ouch - you have issues
change that boutique oil for some 507 - SLX III - run for 3 to 5 k and change it again test at 5k of the second fill of 507 - save your lunch money cause your cam is more than likely going to file for early retirement.
Thats a 2001 go for some real oil - Amsoil DEO - Mobil TDT or Delvac ESP - Schaeffers S9000 is ver affordable. SHell Rotella T. That is just a few of the dozen or more excellent oils your 2001 can use.
Interesting. Which metals are out of line? Did things only improve slightly with the Elf oil? The lab suggested that the oil was fit for continued service for both samples.SUNRG said:XJCoupe - basically the syntec oil was in bad shape by 10k. it's viscosity had become very low for a 5w-40 (10.2 = lower end of the 30 weight range), it was no longer protecting the engine and wear metal concentrations had become high.
Thanks. I will follow that plan, using Delvac 1 or Rotella.if this were my beloved TDI, here's what i would do.by comparing the baseline UOA result (mile 20 UOA) with the 5020 mile UOA result we will be able to clearly determine rates at which your engine is generating wear metals.
- i would change the oil and filter immediately
- drive 50 miles and change the oil and filter again
- drive 20 miles and extract a baseline oil sample, send it to the lab and post the results to this thread
- drive 5000 miles, extract an oil sample, send it to the lab and post the results to this thread
I have a Pela extractor, and used it for both oil changes. For the first change I used the extractor only. For the second one (and for the future) I both drained and extracted.when changing the oil, if possible, i would both drain from the drain plug and use an oil extractor to extract oil from the oil filter housing and the plumbing and oil cooler beneath the oil filter housing.
I will be very interested to see if fuel economy improves. It hasn't been stellar. And, of course, I want to see some good UOA results.if performance and / or fuel economy are at below normal levels, resolving the issues may positively impact your future UOA results and engine longeity.
I will be sorely vexed if I have to do major engine work on this car, but what's life without a few learning experiences? I should be getting some advance warning, at least, if that will be necessary before 300k miles.don't panic. TDIs are extremely durable and often surprisingly forgiving. good luck! and i look forward to seeing your future UOA results.
