chaloux
Just a little to-do list while I'm here, mostly making it for myself as the day this gets started is getting CLOSE!
- do all work that needs to be done on S6 prior to engine swap
- remove AAN from S6
- put 6th gear in 01E
- figure out mounting for ALH as best as I can
- remove ALH from bug, test placement in S6
- do all belts/seals/gaskets etc.
- determine if I'm going to do a power steering pump swap (for brakes) OR perform vacuum assist mod in the S6
- figure out whether to mount to tranny before/after mounting engine
- mount engine/tranny in car
- swap engine harness/wiring/cluster/ECU/MAF
- swap go-pedal from the bug
- install fuel pressure regulator
- figure out fuel lines
- figure out intake tract
- exhaust
Is there anything that I'm missing? I have mounting, air, electrical, brakes, tranny, and fuel covered.
- exhaust
