Old July 2nd, 2008, 17:25   #31
OilGuy
Fuel Economy: ~45 avg (hwy)
CJ-4 defines a minimum hurdle. How far (or if) an oil exceeds the minimum hurdle is harder to find data to support.
OilGuy is offline   Reply With Quote
Old July 2nd, 2008, 19:06   #32
ducatiz
ducatiz's Avatar
Fuel Economy: 35 city / 55 highway
can't you just ask the manufacturer?
ducatiz is offline   Reply With Quote
Old July 2nd, 2008, 20:08   #33
hskrdu
Originally Posted by Bob_Fout
Based on what criteria? IIRC no single one of them can be used to determine which oil is better. They all meet CJ-4 and are all pretty close in their properties.
No, to clarify, I mean that many of us look at the chart and then need to search for an interpretation of the data. A simple note that helps us compare or interpret the numbers would make the chart more user friendly.
Now: 03 Golf GLS TDI 5SPD & (hers) 03 Jetta GLS TDI 5SPD & 2015 GSW TDI 6M
Then: 99 Jetta GLS TDI, 94 Golf GL, 85 Golf GL, 85 Golf, 79 Rabbit C, 68 Beetle, 65 Beetle
hskrdu is offline   Reply With Quote
Old July 2nd, 2008, 20:10   #34
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Ah, something that explains what the different criteria mean?
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old July 2nd, 2008, 20:19   #35
hskrdu
Right, and how to compare the numbers. In other words, when you look at the data, it has immediate value to you. When I look at it, I have to search each item for 20 minutes to figure out what it means, or what value the number holds.
Old July 5th, 2008, 14:44   #36
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
I just pulled an oil sample at 5K on D1 ESP CJ-4, will send in for analysis.
hksrdu I've not forgotten about the labels for ya.
Old July 6th, 2008, 10:51   #37
OilGuy
Originally Posted by Blue_Hen_TDI
TDT CJ-4 is now available at Pep Boys in quarts for $6.49. Here's a pic of what I bought tonight:
Just saw the 1 gal jug of CJ-4 M1TDT at Wally World yesterday.
Old July 6th, 2008, 11:28   #38
TornadoRed
TornadoRed's Avatar
I have a little more familiarity with what each property is, and which values are better or worse. None of the oils in that chart are much different from the others, so there is no way to take that data and calculate which oil is best. Some would say that the M1 TDT, with the slightly higher total base number (10.7), makes it the top choice. Since it's already the oil I use, I don't see any reason to change.
Viscosity Index (VI) is a measure of how much the viscosity changes with temperature. Higher is better, but the differences between the best and the worst in this chart aren't terribly significant.
'03 Golf with 791k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat fuel filter with Nicktane head, DG Panzer w/FMJ, Blizzaks, Delvac1
Become a TDI Club Contributor. http://forums.tdiclub.com/payments.php
Old July 6th, 2008, 11:33   #39
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
TR, I think he's wanting the definitions of each of the various properties. Pour point, NOACK, ash, etc. etc.
Old July 6th, 2008, 12:05   #40
TornadoRed
TornadoRed's Avatar
He can find that anywhere. The Oil Analyzers website is a good place to start.
Old August 6th, 2008, 09:38   #41
fitzski
fitzski's Avatar
VOA results for Mobil Delvac 1 ESP 5W40 (CJ-4)
Not sure if the add pack numbers jive with what we're seeing in the UOA's, i.e. P, Zn, and Mg.
Currently dubless, but formerly:
2004 Jetta TDI-PD [galactic blue, black & tan, 5sp] (Sold.)
2003 Passat W8 Variant [pacific blue, tan leather, 6sp] (Sold.)
2004 Jetta TDI-PD [spice red, black leather, 5sp] (RIP)
fitzski is offline   Reply With Quote
Old August 6th, 2008, 10:26   #42
wjdell
Fuel Economy: avg. 41.93 high 46.32 low 34.6
They really thinned it down, 13 vis. Are you going to use this oil in the passat or one of the Jetta's.
Post your UOA data in the TDI UOA Database thread
http://forums.tdiclub.com/showthread.php?t=205814
~ USED OIL ANALYSIS ~ http://forums.tdiclub.com/showthread.php?t=190958
1.9 PD Jetta V ~ pkg 1 ~
DSG ~ 17" VV ~ 36/34 psi ~
ULSD ~ DG-BP90 - speed 39.2
hwy/city 83% / 17% ~
elev 58 ft / temp 72 F / humidity 76% ~ MPG 48.3 / 42.8 / 35.6
wjdell is offline   Reply With Quote
Old August 6th, 2008, 12:10   #43
fitzski
fitzski's Avatar
It's in the W8. A 13 vis makes it a bit short of a 40 weight... have to see how it holds up. I'll do a 5k mile UOA for sure.
This stuff seems to be all over the map... VOA vis was 13... Bob saw 14 after 5k, Mark is better than 16 after 15k... wth?!
Compare the VOA additive numbers to Bob or Mark's UOAs, though:
http://forums.tdiclub.com/showpost.p...&postcount=641
http://www.bobistheoilguy.com/forums...47#Post1206647
Old August 6th, 2008, 18:13   #44
wjdell
Maybe its not all over - 13 @ VOA - 14.4 @ 5k and 16 @ 15k. Maybe its by design, we know so little about CJ4 at this point. Or, it is a new oil and maybe the batches are running inconsistant. Mobil will get it worked out in time if it its. As for yours, 13 is closer to what VW wants anyway.
Old August 6th, 2008, 19:58   #45
aNUT
aNUT's Avatar
Were clearly missing the forest for the trees here.
I mean - It's the official motor oil of NASCAR! What more do we need???
www.dieselland.net
"Don't speak to me of anarchy of peace or calm revolt
Man, we're in a play of slow decay orchestrated by Boltzmann"
aNUT is offline   Reply With Quote
Page generated in 0.21847 seconds with 10 queries
[Output: 132.20 Kb. compressed to 110.42 Kb. by saving 21.78 Kb. (16.47%)]
