Steamroller69
My differential seals were leaking pretty badly. I decided to remove the transmission and install a clutch and the seals. 150k miles. I removed the transmission and noticed there is front to back movement in the axle flanges. Maybe 1-2mm at most. But this could definitely wipe out the output flange seals. Is a slight front to back movement normal. The service manual mentions a sleeve but i would imagine it could be bearings. I really dont want to split the transmission if i dont have to. Any help would be awesome
