A5INKY
Vendor , w/Business number
Alright, I have been waiting to post my build thread wanting to work out some kinks first. I always enjoy seeing the "this is what I did" threads so much more than the "this is what I want to do" threads.
I am now up against an issue I didn't see coming and need to find a robust solution. From the start of the build I have been working with Mike at TD Tuning (very skilled AND patient BTW) and struggling to get the boost response and clean power my hardware should be capable of. The car has steadily improved but still just not quite right. Mike is seeing strange boost effects in the logs but we have not been able yet to figure out the hardware cause.
Just got a revised tune with some N75 changes and started blowing the IC tube off the turbo. I chalked it up to the not quite right fit on the silicone connector forced by using the stock plastic IC pipe. So I researched and found a much better fitting coupler. I installed it today, excellent fit this time, and blew it off again before I could get a log!
Some details on the build that might pertain to this issue:
This might explain my laggy looking group 11 log and the major overshoot and struggle to correct actual boost? When smoke does clear, it comes back at high RPM in spite of higher boost.
I am hoping some of the euro based builders can chime in about the flow characteristics of the thin OEM FMIC on these cars. Problem for them? what to do about it? Whitbread recommended I look over at Vortex to see what the 400-500HP 2.0T guys are doing for an IC. There is really next to no room for a bigger IC on the MkV. Maybe someone makes a bolt on solution?
For now I am going back to a previous tune revision, will baby the car and leave Mike alone about the tune until I figure out what is going on here. I want to put a pressure gauge pre-IC but it will be difficult with the plastic IC pipe and IC caps. I'll have to think on that one.
Expert thoughts on either the idea of too high pressure drop, or where to find a better flowing FMIC kit?
Thanks in advance!
- Freshened up engine, rings and head rebuild
- Colt stage II BEW cam, mildly ported head
- GTB2056VK turbo with BRM actuator on Driver's Fire manifold
- Tune is targeting only 25 PSI for now
- Full 3" exhaust with Moroso spiral core race muffler only, high flow cat will go in place of muffler once car is dialed in better
- R783 nozzles on ARL bodies
- Stock FMIC and piping
- MAP sensor is mounted in stock location, outlet of IC
- Boost gauge sensor in intake manifold
Thanks in advance!
