jmchugh588
Hi,
Having a problem when ONLY accelerating harsh in FIRST gear dosent seem to happen in any other gear.
From a stand still when taking off the car sometimes plumets out black smoke, it then idles/drives rough for a few seconds before smoothing out again.(propably has over fuelled for some reason). No limp mode and pulls great in any other gear, NO fault codes either.
-unlikely to be boost ive check. Not the turbo or the vnt its perfect.
Could it Possible be an leaking injector, maf or map sensor
Any suggesting's or any members came across a similar problem with there 1.9tdi alh.
