Jh4357
my 2003 vw jetta alh tdi began leaking at the injection pump. I could see the IP leaking from the under the quantity adjuster and its cover, the two I refer to as the upper seals. I purchased a bosch seal kit. Removed the top cover, and then I removed the quantity adjuster portion of the pump when I had realized I mistakenly had not marked the exact location of the quantity adjuster. At that point I just continued to replace the two upper seals. I reassembled the IP and bled the lines with a mightyvac. I kept getting air bubbles in the clear fuel line when I was priming the IP from the fuel return hose. I tried to start the car anyway but it wouldnt start with everything put back together. I figured it was due to the air bubbles I kept getting in the fuel line regardless of how much priming I did. At this point I called it a day and assumed the head seal was the reason why I kept getting bubbles in the fuel line. Since I was going to replace the head seal I decided I was going to pull the pump out of the car and do it along with a timing belt water pump idler pulleys and so forth. Initially I raised the car made sure to set the car in TDC I removed the valve cover made sure the first two cam lobes were pointing up, I bought the special tools so I had the cam locking plate, that fit in nicely, I could see the notch on the transmission and that was lined up, and I also seen the 3 dots on the crank in which I believe it was the first dot lined up with a protruded surface on the case. Everything was lined up I had also locked the IP in place using the locking pin I had received with the kit of special tools I bought for the job. I removed everything at this point used a crank locking gear as well. I took my time and changed all of the seals on the IP. I reinstalled everything and I was able to successfully prime the pump using the mightyvac. I bled the fuel lines at the injectors and the car will still not start. I have purchased a vag com to do everything legit however it doesnt help me since the car is not running. I have since rolled the engine over and the looked at the transmission and then I was able to insert the pin back into the IP. I tried advancing the timing on the IP sprocket and it didnt help. When I say advancing I am referring to loosening the three 13mm on the IP sprocket and just turning the 22mm clockwise toward the front of the car. I tried turning it just a little bit and then tried starting again to no avail. I tried this alittle more each time until it was maxed out in terms of how far I can advance it without loosening the timing belt and turning the sprocket back a tooth.
Something I noticed when I removed the IP was when I removed the IP sprocket initially to remove the IP, the keyway was no longer lined up it was hardly off by mm or two. But I removed the timing belt before I removed the locking pin so i thought that it was fine no big deal I just thought I would mention. And then when reassembling I noticed that the IP keyway on the pulley was in the same spot so I put the spocket on centered it and then installed the locking pin by turning the 22mm and installing the locking pin and then I installed the new timing belt. So now I am unsure what to do completely. I dont know what the issue is tried my best and have fallen short hoping I can get some knowledgeable advice or even a hand willing to help I will pay for your time. I just really want to get my car going again.
