cuban11182
So I've seen how to check fuel timing, and how to make sure your IQ is setup properly, but is there a way to check and see if your timing belt was installed improperly? Say for example someone missed a tooth or something, is there a way to see that without taking the entire thing apart like you're going to change out the belt and water pump?
