paganfx4
I just picked a CPO 2014 sportwagen TDI DSG with 48K. After buying the car I went to do a dsg fluid change, and while replacing the fluid I saw that the front subframe was aluminum
and not steel like I thought the mk6 sportwagen was suppose to have.
Did the 2014 sportwagen have an aluminium subframe, or is this a replacement part?
The one in there looks pretty beat up too and I'm not sure if I should replace it, and if so with which one?
