Foiled
I have a bad 5sp trans in my 2006 Jetta and am considering a swap to a 6 Speed MT. Will a 2006 VW Jetta GLI 2.0T OE MT fit a 2006 Jetta TDI?
Ok, most transmission sellers that I've been seeing are not using a O2Q or 02M model number, they are using the KNS, LHD, KND, MLD, etc codes. I'm trying to find a info source I can use to quickly sift through all the transmissions I find for sale since some of the sellers dont provide all the info they should. I lot say they have a "6sp manual transmission from a 2.0L." I'm always trying to figure out if its gas or diesel .My understanding is that the 02M has a VSS sensor for speedometer whereas the 02Q does not. The 02Q is the model of the trans whereas KNS or LHD is the trans code denoting it's application such as what the ratios are for gas or diesel, etc.
